Old 02-14-2018, 02:55 PM
84cruzer's Avatar
84cruzer 84cruzer is offline
Default Antenna suggestions
Ok I have picked out the Radio I want for my FJ40 Project.
YAESU FTM-400XDR
https://www.hamradio.com/detail.cfm?pid=H0-014544
I just cannot for the life of me figure out what antenna to buy?
What do other have on there 2M rigs? Suggestions?
Little help?
Gary-
TLCA# 20189
AC0UZ
1984 Proffitts TLC FJ60
Old 02-14-2018, 05:28 PM
gahi's Avatar
gahi gahi is offline
where do you plan to mount it? You'll want the dual band antenna, not just 2m
For my fender mount I'd go with one of these I think
https://www.hamradio.com/detail.cfm?pid=H0-000565
I wish i would have done like you and gone with that radio from the beginning. I think i have more then that in my 2m radio, plus my sencond 2m, tt4, 1/4 wave antenna, and mount for aprs. Which isnt neary as elegant.
Gary
1996 FZJ80
2000 UZJ100
Old 02-14-2018, 05:47 PM
84cruzer's Avatar
Default Mount
I'm thinking I will use some sort of a Hood mount
Most likely just fabricate something?
another detail I need to give more thought to.
Gary-
TLCA# 20189
AC0UZ
Old 02-14-2018, 05:53 PM
84cruzer's Avatar
Default A photo to add interest to the thread
Gary-
TLCA# 20189
AC0UZ
Old 02-15-2018, 11:10 AM
What about a bracket on the side, same spot as the original radio antenna?
I am running mine off a bracket that uses one of the spare tire swing-out bolts, and it's out of the way enough though sometimes I think it would work better if its propagation wasn't sandwiched between the tire and body. So I keep thinking of making something that would mount next to the vent kick-out, but then I can't see how that could be done well without drilling another hole, so then I just leave it on the rear swing-out bolt.
edit: here's a picture..
Old 02-15-2018, 02:01 PM
84cruzer's Avatar
Default Too Many Choices
I hadn't given much thought to putting it on the rear of the rig.
Looks good back there. What antenna is that?
I have the FTM350 in my 60 with a comet sbb1 antenna attached to the ARB Bull Bar works reasonably well for what I use it for...
I guess I just want a better mate for the FTM400 on the 40 with better range
I'm starting to think maybe the SBB5 would be a good match from the comet antenna line up?
Gary-
TLCA# 20189
AC0UZ
Old 02-15-2018, 10:01 PM
I think it's a Comet somethingorother.. but don't remember. I've had an SBB5 before and thought it was a great antenna, until I smacked it on a tree branch and broke it- last time I do an upper rear hatch mount.
I like the back of the 40 because it's out of the way, but send/receive suffers being behind a wall. I don't like front bumpers because I don't like looking at them. Middle of the roof is best ground plane but also worst for trees.. side of the fender up front is a decent option, but can be in the way when you're working on stuff. It's all a compromise...
Old 02-16-2018, 12:04 AM
Inukshuk's Avatar
Inukshuk Inukshuk is offline
Subscribed. I am liking my fairly new FTM 400 and so far have only run it on 2M (I did the MARS/CAP mod to "open" the frequencies and had to buy a different antenna for the Baja 1000 race frequency). So I also will need a dual band antenna.
Old 02-16-2018, 06:16 PM
84cruzer's Avatar
Default Leaving this here for future reference
https://myoffroadradio.com/2017/12/1...icle-antennas/
Informative: mostly stuff that has already been discussed here
Gary-
TLCA# 20189
AC0UZ
Old 02-16-2018, 07:40 PM
84cruzer's Avatar
Default Rugged Offroad
Gary-
TLCA# 20189
AC0UZ
