Old 09-13-2014, 09:21 AM
Speaking of checking stuff - when I was airing up after the Bill Moore after-rally run, I saw the split in the split washers under the locking hub nuts looked like it was a little large. Got home and checked and all 12 nuts were practically finger-loose.
Safari Offroad was the last one to touch these, back in 2012. Not really their fault, they can stretch over time.
Old 09-13-2014, 07:07 PM
kurtnkegger's Avatar
My centering bolt on my spring pack was installed upside down, and the nut unwound, and the bolt dropped out. The springs started shifting on the trail, and in turn, the axle started moving. I was able to strap it back good enough to get back home, but new U bolts were needed to get the springs resecured after the new centering bolt was installed. A stressful trip back down the mountain, but all is well again.
Old 09-14-2014, 10:43 PM
I broke a center pin on the left front spring pack at Cruise Moab 2003. Figured it out in the parking lot back in town when I got tire rub, was a WTF? moment. Then saw that the entire axle was pointed to the left. It was an interesting drive home.
I installed a new factory spring pack bolt on that HZJ75, but didn't need new U-bolts.
Why did you need new U-Bolts?
Old 09-15-2014, 04:18 PM
The nuts were so fused to the u-bolt I had to put a big bar on my socket breaker bar, and break the u-bolt off with the nut. Both sides of the axle were like that. I tried to trail fix it, but all I had was a 3/8" socket wrench, which I quickly busted when I applied a lot of force. Lucky for me the wrench broke, and not the u-bolt on the trail. That would have been ugly.
