Old 09-14-2014, 09:49 PM
TonkaToy's Avatar
TonkaToy TonkaToy is offline
Default 40 Brake Booster hisss
Well, the 40 is Alive! From front discs/power steering to 5.7l TBI to new interior and paint...it came out pretty awesome, if I do say so myself. I am one front driveshaft away from being complete.
But, now I have a hiss from the brake booster when I apply the brakes. I'm sure it's got more vac than the old F engine had and I have discs on the front now.
Any suggestions on a cure? Rebuild kits are few and far between as are new boosters. Maybe I need to reduce the vac from the engine? Maybe another model booster is a replacement?
Old 09-15-2014, 12:48 AM
simps80's Avatar
simps80 simps80 is online now
Dam nice looking!!
Both of them trucks..
Not much help on the hiss..
Got the same thing..afaik rebuild or replace is only options.
There's a good thread on mud where vae victus went nuts looking for suitable and equivalent aftermarket replacement booster for 40s and found one
He found iirc an almost identical aftermarket one that worked
Edit: heres that thread I was talking about
http://forum.ih8mud.com/threads/1976...t-list.731418/
From your picture that aint a 76 to 80 like the link above references... but with disc swap on front maybe its what you want anyway..not sure
Mike | KØSMP |
Old 09-15-2014, 08:20 AM
Would just buy a booster for another vehicle. Research fj60, Minitruck, gro metro boosters. I put an fj60 on mine and am happy
Old 09-15-2014, 04:08 PM
kurtnkegger's Avatar
I replaced mine with a booster from a 60 as well. Just be sure to take the back-flow valve with the new booster if grabbing one from a yard.
Old 09-15-2014, 05:03 PM
treerootCO's Avatar
Event Coordinator
I put a booster from an 80 on mine. Direct swap, no mods.... (Mount it upside down)
www.root45.com
www.risingsun4x4club.org
TLCA #14133
Old 09-15-2014, 11:38 PM
TonkaToy's Avatar
Ok, I will look for a 60 or 80 booster. Thanks guys!
Old 09-16-2014, 12:42 AM
bigcity25's Avatar
bigcity25 bigcity25 is offline
I went to "power brake of Denver" got a rebuilt booster for my 40. Swapped it out with no problems. It's a small operation but he knows his stuff. IMO you can skip parts yards and get something that's been rebuilt.
Jeff Billingsley
Denver Colo
7/70 Fj40
desmogged 2f, 4 speed
TLCA #21898
Old 09-16-2014, 02:49 PM
AHorseThief's Avatar
I'm running a mini truck booster on mine. Pretty easy swap. I may even have an extra sitting in the garage.
Nick Kimball
'73 FJ40 Rockin a 327 SBC
Old 09-16-2014, 03:45 PM
This thread needs more pics.
Old 09-16-2014, 05:13 PM
treerootCO's Avatar
Event Coordinator
before:
after:
www.root45.com
TLCA #14133
