  #61
Old 10-14-2014, 07:46 AM
bh4rnnr's Avatar
bh4rnnr bh4rnnr is offline
Geez, really? So that's..
Tim 2
Dave 2
Bruce 1
Ok, no longer going to endorse these to anyone who actually wants to drive on rocks.
Sean Boland had one during last weeks Outlaws Run.
4th gen Coloradoan.
  #62
Old 10-14-2014, 08:00 AM
MountainGoat's Avatar
Club Treasurer
So all the Duratrac failures to date are on LC wagons (60, 80 or 100), right? I have them on my 4Runner and they have been great so far ...
Dan Kucera
TLCA# 17536
KDWJO
95 FZJ80 LC Red
99 UZJ100 LC Black
  #63
Old 10-14-2014, 09:35 AM
Blindranger's Avatar
Blindranger Blindranger is offline
Land Use Co-Coordinator
How low of a PSI was everyone running them when they failed? Seems like if the sidewalls are relatively soft/weak that the lower PSI you wheel at the greater risk to pinch failures on rocks.
Matt Ewalt
KI7IDZ
1996 FZJ80
2016 Sequoia
TLCA #22702
  #64
Old 10-14-2014, 10:59 AM
My friend Jim and I wheeled Left Hand Canyon last year, his first trip, popped his Duratrac. It was a sidewall cut driving his 80. My Toyo MTs are absolute beasts but they are damn heavy. They wear extremely well and stay balanced but man they are heavy and not very efficient.
Paul McCumber - Longmont, CO
1995 FZJ80 -- 2013 Mini Cooper S Hardtop - 2013 Toyota Prius
"It's a 1970 Firebird, the car I've always wanted and now I have it. I Rule!" Lester Burnham - American Beauty
  #65
Old 10-14-2014, 11:21 AM
LXBRADY's Avatar
LXBRADY LXBRADY is online now
X2 on the Toyos....abused them on Sat and no issues, 15lbs fwiw.
I have had several types of MT tires and they have all been 3ply without any punctures to date.
Steve Brady
TLCA # 19524
KD0JVZ
97 LX450
  #66
Old 10-14-2014, 02:08 PM
The tire was at about 18psi. I don't think it was a pinch but more of a pointy rock that put too much pressure on the sidewall as I drove past it. It does shake my confidence in the tires and made me over-think every little rock I drove over after the flat. I'll likely run the remaining 4 tires until another one let's me down.
  #67
Old 10-14-2014, 02:13 PM
I'll repeat again what a local tire dealer told me down here year ago. He quit selling Duratrac's to any oil/gas service truck operators shortly after the tire was released. Too many side wall failures.
Down here the Nitto and Toyo rule the desert on 10,000lb service trucks.
  #68
Old 10-14-2014, 02:51 PM
Our conversation cursed you.
  #69
Old 10-14-2014, 07:56 PM
Inukshuk's Avatar
Inukshuk Inukshuk is offline
To clarify, Sean's was a tread puncture/tear as opposed to sidewall.
I have had a piece of truck chain through a tread block, caused a slow leak, fixed at discount tire.
I had a nail that did not go all the way through (found it at the Rally).
My sidewalls are holding up well after 2 years, 25,000 miles, 2 CM's, Outlaws, Cruiserfest, Cruiserfest pre-run, many weekends. Less than 50% treadwear.
I often air down to 17 lbs on my 80.
  #70
Old 10-14-2014, 09:55 PM
Oh yeah, Sean punctured another sidewall years ago out at Blue Notch Canyon.. a little piece of Tamarisk poked through, remember? Ok I've lost count now.
When both of mine failed I was at about 24psi, which is what I wheel at generally.. wouldn't ever go below 20 with all the weight I carry.
