Old 11-20-2017, 02:16 PM
rckhound's Avatar
rckhound rckhound is offline
Default 3FE gurus needed fj62 starting issue
I have a buddy up here in Summit County that has an Fj62 that is having a starting issue it will start it will run, it will idle for a second and it will die. Pushing the gas pedal down or not pushing the gas pedal down has a similar result. I swapped out the mass airflow sensor with a known one that was good same result. I checked all the wire connections jiggled things checked for fuel pressure all looked good. I checked fuses all looked good. Anybody have any idea this just happened overnight was running and driving fine and then weapons to start the next day and this started happening consistently happens
1965 FJ45 LPB
1995 FZJ80 Lifted, Locked, Geared, and Built
1984 FJ60 Stock and Staying That Way
Sold1979/83 Fj40, 1987 Fj60, 2006 TRD Taco.
TLCA#22362
A nation that destroys its soil destroys itself-FDR
Old 11-20-2017, 04:14 PM
rckhound's Avatar
It's like it allows it to run for a few seconds consistently and and the computer or something completely shuts off spark.
1965 FJ45 LPB
TLCA#22362
Old 11-20-2017, 04:55 PM
Any CEL? You gotta count blinks, but you can pull the codes..
Old 11-20-2017, 04:57 PM
kurtnkegger's Avatar
For sure sounds electrical...I had an old Rodeo that had a similar issue, where it would run OK, and then just stop...like I turned off the key. It ended up being a wire that had rubbed through the casing, and would ground on the body.
Kurt Knudsen
1977 FJ40 "Stella"
KD0VUP
Old 11-20-2017, 05:49 PM
rckhound's Avatar
Yeah the codes were for the MAF and the Temp sensor associated with the MAF. All the wiring to it looks good? Stumped. Pretty sure it was 24 and 32 but cant remeber exactly. Had the FSM in front of me at the time. Is there any other solenoid or switch that could cause it to cut spark or fuel like that? Trouble shooted the ignition switch and it seems to function as it should.
1965 FJ45 LPB
TLCA#22362
Old 11-21-2017, 10:15 PM
Check the air intake hose very carefully for cracks - always worth checking on an older truck.
Old 11-26-2017, 01:07 AM
Dang newfangled computer-FI stuff!
