Old 04-14-2006, 09:42 AM
cricket
Guest
Posts: n/a
Default ?axle strength?
i have an 02 tj x with 30 and 35 i have a 7" long arm and 2 " body w 35's i was wandering how u guys think the axles will hold for now till i can get stronger ones im broke
Old 04-14-2006, 10:00 AM
FJBen's Avatar
FJBen FJBen is offline
If you make it to the trail head with that rear axle I'd be amazed. If you take that rig 4 wheeling, don't go alone. That rear D35c usually dies with 33" tires. I'm assuming you AREN"T locked so that will help....sorta...maybe...not really but go for a 8.8 rear end.
I don't know if you've noticed or not but this is the Rising Sun 4wd club, which is TLCA sanctioned...or Toyota Land Cruiser Association. Nobodyon here has a jeep for reasons I won't go into...but...
here are some sites which will be a big help to ya, unless you'd like to convert to Toyota
Good local site, 95% jeeps
www.colorado4x4.org
All jeeps, not local, kinda gay site....ok really gay but you could prolly get better answers than what we would give you...
www.jeepsunlimited.com
TLCA#15530
96 285's OME 's ride
Old 04-14-2006, 10:08 AM
Word!
Cricket, we like ya but ya gotta do somethin' 'bout that truck!
www.colorado4x4.org
KØUBN
Me ain't sure what a 30, 35 is.. is that 30 inch tires on the front and 35's on the rear
Toss some 60 axles under it with a 2f and split case and you should be fine
Cricket, don't mind our little bashing.. It's all in good fun here but were mostly dedicated to Land Cruisers and Toyota's in general. Only uncle ben know jeeps
WØREK
Old 04-14-2006, 10:12 AM
Originally Posted by wesintl
<snip> Only uncle ben know jeeps
He knows thay taste like chicken!
KØUBN
Old 04-14-2006, 12:09 PM
You guys is bad to the bone...
Cricket, you are pushing your axles hard but they can either be upgraded, or the man above is correct: an 8.8 Ford axle is stylin', gives you disk brakes, and IIRC also can be had, from the boneyard, with 4.10 gears. Which should pull those 35s mo betta.
The front can be beefed significantly, and needs to be. You really will NOT like replacing a front U-joint in the rain, at night, in the dark in the middle of nowhere. Just as much un-fun as a birfield, the Toyota equivalent. High Country 4x4 can help you out there, or perhaps Wilderness Off-Road. Shoot them a call.
KDØRCH
Old 04-14-2006, 03:33 PM
Nay's Avatar
Nay Nay is offline
These Toyota guys should be promoting their junk. Put a Toyota 8" in the rear out of a 3rd gen 4Runner. Can be had in factory 4.56, and you get the axle size and splines of a D44 with the diff clearance of a D35, plus factory e-locker option (maybe just mod it for a cable shift?).
People do the Ford just because it has the same bolt pattern (5 on 4.5), but you still have a c-clip axle and you'll love an inch of diff clearance compared to the Toy 8".
The 30 is fine until you have seriously upgraded the rear.
Nay
Old 04-14-2006, 04:01 PM
Nay's got quite a point there. Why not?
KDØRCH
Old 04-14-2006, 04:25 PM
cricket
Guest
Posts: n/a
Default thanx
haha oops didnt realize the whole land cruiser thing but wheelin is wheelin so yea well thanx 4 the info i thnk im gonna do the 8.8 swap cause of money
Old 04-14-2006, 04:45 PM
Seldom Seen's Avatar
I WAS a Heep guy had to learn the hard way.
Another option for the rear, that's little known even by the Joop crowd, look for a Ford 9" from a late 70's -> early 80's Lincon Town Car or blue oval station wagon. Close to the same width, some came w/ rear disks, and the same lug pattern.
