Old 10-31-2017, 01:03 AM
Disappointing
Question Jerry can holder recommendation?
I need to buy or create a cage to haul a gasoline jerry can or two outside my 80. I have a 5-gal red steel Blitz jerry can and a plastic Scepter can of about the same size. I'm thinking I can weld some tabs on my rear bumper and attach one or both of these with a cage designed for the purpose.
Or I could buy some of those RotoPAX containers, which is attractive since they are smaller and easier to handle. I might even be able to mount one behind my spare tire, which would be nice and tucked away.
1. What do you have and what do you recommend?
2. Do you carry 5 gallons or 10 gallons of extra fuel?
Thanks!
Originally Posted by nakman
Old 10-31-2017, 10:01 AM
Inukshuk's Avatar
Inukshuk Inukshuk is offline
I like the 2 gallon rotopax. I keep two on the roof for average trips. I can leave them on top when I go in and out of my garage. Only problem is they bulge in heat, but never have leaked and return to form when cool. The two gallon size is easy to handle. If you get rotopax be sure to blow them out with compressed air prior to use. I always find some plastic shavings in them when new.
I also have 5 gallon waivan jerry cans. I lie them flat on the roof. I can carry up to 5 and just added some tie downs that will make it easy to carry 4 and quickly strap down and remove. I fill the truck direct from the roof with a super siphon (to which I added a 1/2 inch Wix fuel filter). I have three that are probably 18 years old. The linings failed (peeled off in large flakes) and I have re-lined one. It was a PITA. I bought two new ones at FJ Summit from Pure FJ that had them on sale. On the old ones I have replaced the seal once. It was not leaking but had some visual dry rot cracks.
For the eclipse trip it was nice to have 25 extra gallons.
I calculated about 150 pounds on top for fuel. I do not feel the weight affects handling. It already handles like a big, heavy, lifted Land Cruiser. Those long trips are not rock crawling. Nice to have the extra range.
Old 10-31-2017, 11:30 AM
Run them off your spare. http://www.risingsun4x4club.org/foru...ad.php?t=25776
Old 10-31-2017, 12:11 PM
I like rotopax but man for 2 gallons I am only getting like 24 miles... Matt if I were you, I'd keep the 5 gallon ones you already have or sell them both and nab some new NATO cans at Jax or similar...
I am happy to bend some hoops if you want to knock up a quick rack and can weld them. I was planning on adding a rack here soon for my ARB and gas cans, I'd be happy to bend up another cage for you if you are interested.
Old 10-31-2017, 12:24 PM
If you go to Jax make sure you're getting real NATO cans. The metal Blitz type can they have now are the California compliant ones with the special nozzle.
I agree with Drew otherwise about Rotopax, a lot of money and trouble for what you get. Figure out a way to carry 5 gallons to make it worthwhile.
Also, don't be an idiot like this guy. Any number of things could wrong here, theft, leaks, propelled fireballs in a fender bender.
Old 10-31-2017, 03:31 PM
I have some Legit (french military) Nato cans (not the BS crap copies) I use that I just toss in the truck. They have old seals and don't leak. I figure I'd smell the gas if they did long before I blew up.. maybe I am mistaken
But come to think of it, you probably want space in the truck. Also, now that I remember your truck also has leather... Even if mine leaked they'd only help mask the old musty toyota smell. You may not be willing to take that risk.
Old 10-31-2017, 03:39 PM
Think about it Marco, if you can smell the fumes your truck is filled with gasoline vapor. It's not a good idea to put gas cans inside any vehicle but inside the passenger compartment doesn't strike me as an improvement. You add potentially explosive to noxious and oxygen displacing. Gasoline vapor is heavier than air, so undisturbed by the time it reaches your nose it's fairly dense lower. OTOH, the rust holes in the floor are probably good vents.
Old 10-31-2017, 05:55 PM
dan1554's Avatar
dan1554 dan1554 is offline
I thought this was a pretty neat idea. Looks like a lot of work though.
https://forum.ih8mud.com/threads/und...#post-10396593
WA6AIJ
Old 10-31-2017, 08:09 PM
yeah.. have fun pouring the gas in your truck with all the crunchy road bits.
Old 10-31-2017, 08:11 PM
Very good points Dave. The rust holes must act as good vents
