Old 11-26-2017, 01:37 AM
Lastresort576's Avatar
Lastresort576 Lastresort576 is offline
Send a message via AIM to Lastresort576
Default fzj80 Vehicle Speed Sensor
So it appears that my VSS took a crap on me.
The whole speedo unit in the gauge cluster is no longer working. No biggy. But It's to my understanding that there are two VSS on these wagons, 1 on the trans and the other on the T-case. Is there any way to figure out specifically which one went bad? Also, are both VSS the same?
Thanks
'97 LX450
04 Civic Si
'16 RAV4
'68 MGB-GT
Old 11-26-2017, 07:00 PM
LARGEONE's Avatar
LARGEONE LARGEONE is offline
Interested in the answer. Sorry can't help. But I'll bump for ya
Paul
KE0OLZ
1967 FJ40 - Nearly Stock
http://www.vrbo.com/322094
Old 11-26-2017, 11:43 PM
So I had a few minutes to get under her today. Could only find the one on the tail if the T-case. It was caked with grease, dirt, etc. so I cleaned up the connection and sensor, added some dielectric grease to the connector. But no dice.
Gonna hit up the Denver PullnPay tomorrow and take one out of a Previa. It’s evidently the same VSS. Hopefully it works.
My guess as to why it went bad is that I’ve got a bad Ujoint and some rear shaft vibration plus the 239k miles on it.
'97 LX450
04 Civic Si
'16 RAV4
'68 MGB-GT
