  #41
Old 08-14-2008, 05:22 PM
Duh, BL = body lift. I read that as 'B'all joint 'L'ift. Such a dork. Don't have a body lift, thus why my fender-met-a-BFH.
Drop the diff. No more blown CVs. Angle it a bit and you still have a smooth front driveline too.
Diff drops don't seem like they'd be very easy on our generation IFS because of the front cross member. It pivots the pinion down if you lower the rear two mounts because of the front mount being pretty inflexible. Plus with a diff drop it makes the rear IFS truss harder to fit (just need a custom one, off the shelf units assume none).
Attachment 10192
BTW, Steve Schaefer's shop truck is a pretty good example of a capable, budget build.
http://www.yotatech.com/f86/sonoran-...y-28-s-104077/
  #42
Old 08-14-2008, 07:38 PM
cbmontgo's Avatar
cbmontgo cbmontgo is offline
Attachment 10192
Cool.
These rigs with the 3.0 V6 that came later...how hard is it to change out the timing belt and head gaskets that you always hear about? Those early 90s 4Runners are dirt cheap these days too...
What do you guys think about those? No top off, but I always liked the body style.
'76 FJ40
'77 FJ40
'83 HJ47 diesel
'96 FZJ80
'00 UZJ100
TLCA # 14207
  #43
Old 08-15-2008, 09:00 AM
Royal pain in the butt. Not an easy motor to work on. Lousy mileage too - although with only 31s and in prime tune I did get 21mpg out of my '89 XtraCab 3.0 on the highway. Before the HGs failed.
I never got better than 15mpg in my '90 4Runner 3.0, however. Before and after its HGs failed and we had to put in a new shortblock (wife drove it at that time ).
It IS, however, a great platform for a 3.4L swap! The most painless one in fact. That would be the only reason I would buy one.
KDěRCH
  #44
Old 08-15-2008, 11:51 AM
cbmontgo's Avatar
With a new head gasket and timing belt, would the 3.0 be a pretty reliable engine?
'76 FJ40
'77 FJ40
'83 HJ47 diesel
'96 FZJ80
'00 UZJ100
TLCA # 14207
  #45
Old 08-15-2008, 12:23 PM
With regard to the 3.0.
I have a buddy with a 3.4 swapped truck, 95 4runner.
With the 3.4L motor, he has more power, better gas mileage, AND he gained TONS of room in the engine bay.
I cannot think of a toyota motor that is worse to work on than the 3.0.
IMO, don't bother.
  #46
Old 08-15-2008, 12:24 PM
For all of the bad rumors, the 3VZ is really an OK motor. It does not make much more power than a 22R-E and so the risk/reward isn't high, but with good headgaskets they do last alright. Can do 200K when they don't blow HGs and get regular maintenance. Like Isaac says, the 3.4L is a better motor, but is it worth the time and effort to swap? Hard to say, if you have a 3.0L that's running OK it would be hard to justify for me to spend the money and weekends swapping it out just 'cause. I would not rebuild a 3.0L, though.
  #47
That is a cool truck right there
Okay, shameless plug for my truck, I'll admit
  #48
Old 08-15-2008, 12:26 PM
In my opinion, based on experience, having been 2 for 2 on premature HG failures, one costing a short block, on well maintained machines, I would have to say no. The head clamping arrangement is substandard, and the things cannot breathe.
Brian Cobain did his 3.4L swap into a pre-96 4Runner in a weekend. While he is a very good mechanic, this does let you know the swap is not unreasonable.
A 3.4L in a first generation 4Runner is just about ideal in terms of power, reliability, and mileage. Plus grin factor. Supercharge it, and you better get some teeth whitener cuz folks will get a lot of chances to inspect them.
KDěRCH
  #49
Old 08-15-2008, 02:25 PM
cbmontgo's Avatar
Hmmmm.
I just found a perfect condition 1990 2nd gen 2-door (rare) with a new head gasket, water pump, and timing belt replaced with 186,000 miles, no rust, and good maintenance history. Such a clean rig and runs great...but I am nervous about this motor from what I hear here. It is cool because it's so unusual, but...
'76 FJ40
'77 FJ40
'83 HJ47 diesel
'96 FZJ80
'00 UZJ100
TLCA # 14207
  #50
Old 08-15-2008, 02:39 PM
Hmmmm.
If it runs reasonably well and the price is fair, I wouldn't worry much. Having a 2-door 2nd gen 4Runner would be cool alone. So what if the engine goes, put in a 3.4L and have a super cool truck. If the engine is original with 186K and has had the HG recall done, it's probably good for a while more.
