Old 11-12-2006, 07:33 PM
Default wanted: dead winch rope
EDIT: see below
Old 11-12-2006, 08:37 PM
Originally Posted by subzali
So for senior design we are looking at using cables to suspend a platform to walk across, and I was wondering if anybody had some spare winch cable that they weren't using they'd be willing to donate. It should be strong enough to support the weight of a person right? If there are four of them to support a person's weight?
Anyway I don't need much, we have a nominal distance of 10 feet to span, so nominally 40 feet, figure 60 feet just in case we screw up something or need extra for tensioning/whatever. Anybody got some? BTW what kind of diameters does winch rope come in? 3/8? 1/2?
I have an unused stretch of 3/8" x 94' wire rope you can have.
Old 11-13-2006, 11:29 AM
CardinalFJ60's Avatar
Default I've got some, too...
I too have some wire winch cable. ~100' It's got one kink in it, not sure how much is 'good' on either side of the kink...
-s
Old 11-13-2006, 11:21 PM
EDIT: see below
Old 11-14-2006, 08:23 AM
So we will be cutting it up into pieces and you probably won't get it back, just to be clear. I can pick it up at the next meeting or work something else out. Thanks guys!
What you do with it would be your biz!
Old 03-30-2012, 12:04 PM
BUMP.
I'm on the lookout again for some junk wire rope/winch cable that folks have laying around and just need to get rid of. Let me know what you got.
Old 03-30-2012, 05:31 PM
I've got what comes with a M15K (90' of 7/16" IIRC)
I don't think it was ever used. I was holding on to it for possible use on Jenny Creek or Argentine as needed. Since you are sort of heading those up, if you don't think we can put the cable to use on either of those then you can have it
Old 03-30-2012, 05:54 PM
Jeff, do you mean for building post- and cable fences? I'm not sure, but I think the Forest Service typically likes to use new cable for those projects, and knowing the government, probably has specifications for the diameter, type, etc. which that rope may or may not meet. Also, 90' is pretty short for post- and cable projects, it just doesn't get you very far.
But I am planning on needing this for a different type of project up at Argentine (a winching project), so it would still go to a good cause!
Old 01-26-2015, 10:07 PM
Bumping this thread. Any old winch cable that's just sitting around I can give it a good home. Don't throw it away!
Old 02-02-2015, 09:07 PM
Pretty sure the cable I have is still sitting in the same spot it was 3 years ago
HTML code is On
