  #51
Old 12-18-2008, 10:14 AM
Yeah I'm going to POR-15 it next spring to help make sure that happens
  #52
Old 02-03-2012, 11:51 AM
Thread revival...
Last week and earlier this week I had no heat. Even going down the highway.
Then I checked the coolant level and found that the overflow bottle was empty. Filled it up and I got heat now. Coincidence? Dunno...
Is the heat system really that marginal? That if it's a 1/2 gallon low the heater won't work?
Once I get a house and a garage to work in I'm going to pull the drivetrain and clean and reseal it (rear main leak), fix the radiator, replace all the coolant/heater hoses, flush the heater cores and pipes, get Shane's kit to rebuild the heater, reseal the heater duct, get a new heater control valve or clean the one I have, and POR15 the gas tank. And take a close look at my clutch. That should keep me busy for a few days.
  #53
Old 02-03-2012, 12:30 PM
I dunno about POR15 for gas tanks. Witness your observation that fuel ate through it!
I used this product for the Ducati (plastic tank vulnerable to ethanol, this is a common fix):
http://www.webbikeworld.com/t2/caswe...l-tank-sealer/
It is available in quantities for auto fuel tanks and is bombproof.
KDěRCH
  #54
Old 02-03-2012, 12:37 PM
When your overflow bottle was low, did you check and fill the radiator at the same time? Usually, when the overflow is low, the radiator is low, too.
  #55
Old 02-03-2012, 01:13 PM
Squishy!'s Avatar
Squishy! Squishy! is offline
If your heater core is higher than the "low" level in the radiator it will fill with air and presto! no heat. and yes 1/2 gallon is roughly 20% of your capacity IIRC.
-Justin Morgan,
TLCA #23166
"RedChili"-1987 Super Beast
  #56
Old 02-03-2012, 01:30 PM
I'll check that out, but the POR15 would be to protect against rust/abrasion on the outside of the tank. It's a brand new OE tank now so there should be no pinholes to worry about for a while.
Didn't know that about plastic tanks though - maybe I should think about that on my KTM? I would think that the OEM's would know that and change the plastic to resist ethanol?
I didn't, because the engine was hot at the time and I didn't want to spray coolant everywhere. I still need to check and make sure that it's still full. It did start filling the overflow right away though, so I don't think the overflow was completely empty. I don't know where my coolant is going, the leaks in my radiator aren't that big
I think that the coolant capacity is somewhere around 4 gallons? Yes, 16-17 quarts.
  #57
Old 02-03-2012, 03:17 PM
PabloCruise's Avatar
Thread revival...
What is a Shane's Kit to rebuild heater?
My heat is very marginal in the 40.
What is the best way to clean a heater core? I seem to recall hearing muriatic acid soak is the desired protocol?
TJS K0TNP
1978 FJ-40
1974 FJ-55 w/ 3FE
TLCA #10713
  #58
Old 02-03-2012, 03:23 PM
Shane on MUD, aka AATLAS1X
I assume that is who Matt is talking about. Not sure if he has his own website now or not. He makes all sort of stuff including new leather seats for the 80 series, reproduction stickers, etc.
  #59
Old 02-03-2012, 05:04 PM
It's funny to hear you have these same issues. My heater didn't work when I bought my 40 (never got hot), and my cooling system would either run way too cold (wintertime), or borderline overheating (summer).
New radiator, new hoses, thermostat and a heater rebuild did the trick for me. Heat blows like crazy, and the cooling is consistent and perfect all 4 seasons. It's one of the best things I did for my 40.
  #60
Old 02-03-2012, 07:43 PM
kurtnkegger's Avatar
I purchased the heater kit from Shane for my 40. The kit consisted of foam sheets to glue on the gate (you have to but the glue separately), Foam strip to seal the heater core, more foam for the blower motor, and some small plastic bushings for the gate posts. There may have been some small screws for the gate as well. He'll give you a deal if you mention you are a mud member if ordering from ebay.
Worth the money to get a good seal on the heater. My heater worked way better after the rebuild...
