Old 11-07-2017, 03:05 PM
74fj40's Avatar
74fj40 74fj40 is offline
I say tape your phone to the windshield!
2005 Silverado 2500hd Duramax
1972 Toyota FJ40
1967 Porsche 912(100% stock)
[/font]
Old 12-11-2017, 07:51 AM
White Stripe White Stripe is offline
Originally Posted by frontrange View Post
That would take a helper, maybe SteveH will volunteer next time he comes over.
I am planning on coming up to Denver for the next meeting to join R/S if anyone planning on being at the meeting anyway wants to see it run live.
Updates?
Old 12-11-2017, 08:32 AM
Sadly, I blew head gasket last Monday. I'd been fighting an overheating issue I think I had just solved, but too late to save the gasket.
Timing was bad as I'm really busy with work so I haven't been able to make the time to replace it. Guess I'll have to try again for the next meeting in January.
TLCA #23619
  #24
Old 12-12-2017, 12:46 PM
That stinks. Sorry to hear. Why was it overheating?
  #25
Old 12-12-2017, 01:28 PM
Awe thats a bummer... sorry man. bump in the road I guess, not too bad of a fix so thats good..
  #26
Old 12-12-2017, 02:28 PM
Red face
The bottom line is the turbo and it's water jacket complicated things with a new long loop to trap air and I had no provision to vacuum it out. The last thing I did after seeing the temperature spike in the road was fit an overflow bottle made of al with a flare fitting on top to apply vacuum, but it was too late I guess. I had already done the damage the last run. I was literly just trying to get it warm again to draw coolant into the radiator before vacuuming the air out when I realized the gasket was already toast.
Its not all bad. I already had decided to replace my intake with a 3FE, so I had a chance to figure out what had to be moved in order to make room.
TLCA #23619
  #27
Old 12-13-2017, 08:51 AM
Cool. Did you upgrade any internals? Or simply balance the OEM rotating assembly?
  #28
Old 12-13-2017, 09:00 AM
Not really. I did coat the skirts of the pistons with a dry film lubricant and the tops with a thermal coating. And the distributor was replaced with a missing tooth wheel on the crank and Ford EDIS ignition.
That's about it at this point but I have a lot of custom parts that I've made over the last few years that will be added to it over time.
TLCA #23619
  #29
Old 12-19-2017, 12:22 PM
Look forward to your progress.
  #30
Old 12-19-2017, 12:39 PM
As a follow-up, I discovered that the gasket didn't fail due to heat. It turns out there was a small pinch in the armor around cylinder #5, and that was where the leak started. I just didn't notice it till it failed. It looks like the gasket got damaged before I installed it (maybe something dropped on it?), and I didn't inspect it closely before I put the head back on, my bad.
I'm going to fix a couple other minor things before putting it back on the road. I noticed my missing tooth wheel for the EDIS ignition was off by about 4 degrees, something easily compensated for in the tuning S/W, but I decided to cut wheel another and get the next one installed at exactly TDC before putting the head back on.
Also, I drilled and tapped the head for a third NPT port for a K type thermocouple so I can get a much more accurate temperature reading than I've been living with so far.
The last thing I plan on doing will be to make another downpipe for the turbo that will incorporate an external wastegate since I have a minor linkage interference problem with the integrated wastegate and the 3FE intake I want to install next spring. I also need to fit a floor mounted parking brake lever, its cable coming out of the firewall was the other thing that interfered with the 3FE intake.
TLCA #23619
