Old 05-04-2015, 10:20 PM
Default Entertaining tire suggestions - FJ40
I need new tires. Want something that works well, looks cool, and isn't a BFG AT. I just need to be more different than that, even though it's probably a decent choice. Just want something more 40ish, more militant looking. Here are your other variables:
Will be getting OEM rims, which are 5.5" wide, 15". Suspension is the OME 2-2.5" Dakar kit. Uncut fenders. 3:73 gears, stock 4 speed.
I think a 32" tire would be the right size. In my last 40 I ran 33" x 10.50's on 60 series rims, with stock springs. So I am pretty certain I can still run a 33. But for efficiency reasons am thinking 32 is better. Plus those 33's really stuffed in there, I didn't rub but also didn't wheel that hard... (name that trail, Jacket)
Old 05-04-2015, 10:26 PM
Here's a pic of the rim/color combo we're shooting for. But yes I know, BFG AT's..
Maxxis makes a buckshot mudder in a 32 x 11.50. that would fit, right?
http://www.maxxis.com/catalog/tire-1...uckshot-mudder
I would also run Bughorns again, in fact this is likely leading the pack here in the 32 x 11.50 http://www.maxxis.com/catalog/tire-1...bighorn-mt-762
what else is out there?
Old 05-04-2015, 10:36 PM
Romer Romer is offline
I have Toyo AT II's on my 100 series. I flipped a coin between those and the new BFG AT KO2's. Both are new tire designs and the Toyo MTs have always been good
I do have the BFG AT KO's on my 40 with a 2.5" OME DAKAR lift which is smaller than the lift on my um your old 40 when you bought it.
Old 05-04-2015, 11:24 PM
What size BFG's are you running?
Old 05-05-2015, 08:11 AM
33x10.5x15 BFG ATKOs
Old 05-05-2015, 08:54 AM
rckhound's Avatar
rckhound rckhound is offline
Default Tires
I really liked the KM2's on my 40. They were 33x10.5 though.
1965 FJ45 LPB
1995 FZJ80 Lifted, Locked, Geared, and Built
1984 FJ60 Stock and Staying That Way
Sold1979/83 Fj40, 1987 Fj60, 2006 TRD Taco.
TLCA#22362
A nation that destroys its soil destroys itself-FDR
Old 05-05-2015, 09:26 AM
Slaughterhouse?
Cooper STT's come in 32x11.5x15. They chunk and get noisy with age, but so do the Bighorns. Noise isn't as big an issue with a 40 though.
Old 05-05-2015, 09:50 AM
Is 11.5" wide on 5.5" rims alright? That would seem to me to be a bit much. I thought 33x10.5 on my factory 6" rims was pushing it and liked them better on 7" rims.
A 32x11.5x15 is a 285/75R15, you can use this calculator to see what it would look like.
http://www.rimsntires.com/specspro.jsp
Old 05-05-2015, 10:09 AM
Yea - 15" rims are tough; the size selection is limited. An ideal size would be 235/85/16 for 32" of height, which is what I may run next (currently I'm on 255/85/16).
Dave raises a good point. I'm not sure I've seen anything wider than a 10.5" tire on the OEM FJ40 rims.
Old 05-05-2015, 10:12 AM
TSL radials in a 32 x 10.5
http://intercotire.com/tires.php?id=14&g=1
