Old 05-29-2009, 03:41 AM
Default Emissions Testing...What are your results?
The 80 was due for tags and needed an E-test to boot...Yesterday the CEL came on and it was the dreaded PO401 code - I reset the code and hoped for the best so I could get the E-test done...Drove the truck about 60 miles today (engine was nice and hot) before the test and it passed, but not with flying colors. So, I got to wondering how the test results compared to past results and to the LX test results. I also recalled some folks saying the "limits" on the E-test have gotten stricter recently and I wanted to see what changed. What is nice is that I have 2 rigs that are the same age, have similar miles, and were purchased within about 3 months of each other, to compare against one another.
Here is a pic of a quick table I made up...
The first real obvious thing is that the limits for HCs and NOx have been dramatically reduced to ~1/3 of what they were two years ago. The CO limit has also been reduced, but not by near as much as the other two.
The other thing I noticed is that while the LX's reading have improved since I purchased it while the FZJ80's number have gotten worse. I was close to not passing the E-test due to the NOx reading.
I am interested in what readings the rest of you are getting when your rig was tested as well as hearing any thoughts on why there is such a dramatic difference between the two rigs
FWIW, both have the MAF mod and aside from the LX being built up they are very similar. I change the oil more frequently in the LX due to the warranty requirement. Driving wise they are both mostly city driven rigs, i.e short hops. I am assuming that since the 80 threw a PO401 code that I have some issues that will need to be addressed here in the near future.
Last, here are what Envirotest states about high readings:
High HC Readings: High HC readings are a result of unburned or partially burned fuel.
High CO Readings: High CO readings occur when the air/furl mixture is too rich
High NOx Readings: High NOx readings are the result of high combustion temperatures and/or high combustion pressures
So...what in the he%& does it mean when all 3 are high? How can the rig be running rich but yet have high combustion temps? Shouldn't running rich mean the combustion temps should be lower? That is how it works in a piston engine plane anyway . I can see where a high HC and high CO go together but not the NOx.
I was thinking the MAF mode is screwing things up by if that were the case the LX's numbers should be a lot worse as well, and they are not.
Old 05-29-2009, 10:53 AM
Your high NoX is a result of your EGR flow code p0401. EGR introduces a inert gas into the combustion process to cool the burn. When temperatures reach a certain point durring combustion your engine starts to produce more NoX.
Your higher CO could be caused by a slower to respond oxygen sensor. Co is created when there are not enough oxygen atoms to bond with the carbon durring combustion, too much fuel, or running rich.
To clean up your truck I would first start with fixing the EGR system. I have seen EGR cause a rich condition on those trucks even though you would think it should be the oppsite.
Edit: I now see way more failed emissions here now at Burt due to the strict standards now in place. 80s are now failing emissions when before we never would see any.
Old 05-29-2009, 05:06 PM
Thanks for the info Brian
Guess I'll start futzing with the EGR crap or take the Nakman route and have Robbie make the problem go away - I read up on some of the threads (here and on MUD) and this seems like an area where they is no one magic fix or part to replace that resolves the problem. Seems like many folks decided that after 100K to just start replacing everything including O2 sensors but that could get expensive REAL quick
I am amazed at how much more strict the limits are - That is a drastic change...
BTW, how is the project 80 coming along?
Old 05-29-2009, 05:08 PM
I replaced both catalytic converters and passed with flying colors.
Originally Posted by nakman
Old 05-29-2009, 11:40 PM
The UZJ80 is going slow. I've run out of funds. Just started wiring this week, need to build the exhaust and lots of other small things. Get some drive shafts built.
Old 05-30-2009, 02:43 AM
You need to start doing some business on the side to generate the funds to finish that sucker off
Old 09-08-2015, 07:11 PM
bruce285's Avatar
bruce285 bruce285 is offline
The '94 80 I just bought is testing with a high Nox (NOXGPM test reading:6.4634 limit: 4.0000 results:FAIL) I had diagnostic done Stevinson E. the results best guess for the problem is the EGR valve fail. Ideas?
God has no Religion- Mahatma Ghandi
TLCA Member# 23562 KE0FUO kilo-echo-zero-foxtrot-uniform-oscar
'64 FJ40 Chevota heavily modded
'94 FZJ80 Toyota locked & stock
'09 Yamaha V-Star 1300 bagger
Old 09-09-2015, 07:50 AM
If you have the FSM you can check the egr valve operation yourself. Didn't the dealership do this? You say best guess...
Old 09-09-2015, 04:26 PM
bruce285's Avatar
FSM? What I had done at Stevinson was a simple diagnostic ($125), not the full smog failure service for $250. The EGR was the one code out of eight stored in memory that tested ON. I pulled the EGR valve and cleaned it; though it did not appear to be clogged, nor was the valve port in the intake manifold. Had the diaphragm checked with vacuum tester: the diaphragm moved but whether or not it holds vacuum pressure was inconclusive.
I retested after running the rig fairly hard (AC on) and the test results were worse than the first go around, and it failed NOX again with the addition of high CO fail. I am going to replace the EGR as the valve may be stuck. I wish there was an alternative to emission testing to find out if maintenance and or parts replacement performed have changed the test results to passing.
Old 09-09-2015, 04:32 PM
bruce285's Avatar
Additionally, the codes for OBD1 have different designations than codes for OBD2. I think the P0401 (OBD2) corresponds to 71 (OBD1) code.
