Old 06-04-2009, 09:08 AM
LXBRADY's Avatar
LXBRADY LXBRADY is offline
Default Looking for reliable/honest mechanic on the South Side
The 40 sprung a leak last night. Small puddle in front of the firewall on the drivers side tight to the fender. Brake fluid fine, engine oil fine. I suspect it is related to the clutch as the PO mentioned he replaced the clutch not long ago and the oil is fresh.
Please advise.....
Steve Brady
TLCA # 19524
KD0JVZ
97 LX450
Old 06-04-2009, 09:36 AM
I don't have a mechanic/shop reference for clutch work. How is the fluid level in the clutch master reservoir? If the leak is in the clutch system, I would expect to see the clutch master reservoir low. As the leak is recent, taking a look at the slave cylinder, hose between the master cylinder and slave and the master cylinder should might be a good next step to determine what has failed and needs to be replaced.
When sourcing cylinders for the early 70's there are some specific things about the fittings that you need to keep in mind - Jeff Zepp has some good information on his website about replacing the master cylinder. Rebuild kits are readly availalble. All that said, there are upgrade kits - new cylinders and hose available. If you want to go the upgrade route, take a look at part #CHC40 from JTO Outfitters.
Old 06-04-2009, 09:59 AM
Toy Car Care is a pretty reputable shop. I think they're kinda south side.
Or Rocky Mountain Cruisers
Old 06-04-2009, 10:23 AM
LXBRADY's Avatar
Thanks Ricardo, I will check what you suggest. The challenge with this truck is that is has parts from multiple years and multiple manufacturer's. I think the only thing original is the steering wheel!
Matt, thank you for the suggestions....I may be setting up an appointment if I can not diagnose by the end of today.
If any one else has idea's/suggestions please post.
Steve Brady
TLCA # 19524
KD0JVZ
97 LX450
Old 06-04-2009, 10:38 AM
pics.. we can help diagnose what year master etc.
WěREK
Old 06-04-2009, 11:07 AM
LXBRADY's Avatar
Just took it for a short spin around the block....no leaks, everything is tight and topped off. I will take it out for lunch and report back.
Steve Brady
TLCA # 19524
KD0JVZ
97 LX450
Old 06-04-2009, 11:22 AM
Huh. Wonder what that is like.
KDěRCH
Old 06-04-2009, 11:56 AM
Are you sure that it's hydraulic fluid? What's the color, smell, etc? Small puddle could easily be a slight leak in a rad hose or maybe an oil seal weeping a little.
Old 06-04-2009, 12:04 PM
LXBRADY's Avatar
Lt lt gray in color, very thin fluid and no odor.
Steve Brady
TLCA # 19524
KD0JVZ
97 LX450
Old 06-04-2009, 12:12 PM
Should it prove to be a bigger issue that you can't/done want to tackle, for honest mechanics that might be able to help out you could try Three Wheel Ben and/or Squishy on the South side.
For FJ40 stuff I always went to Ron @ RMC first but that appears to be an option that is going away
