  #101
Old 09-08-2009, 11:30 AM
Doood......Your truck is very impressive but even with the tremendous efforts you have put into it it still looks like a 4Runner....sorry.....
Well, only the best for me....I wouldn't want to settle for a Land Cruiser or anything.
  #102
Old 09-08-2009, 11:38 AM
You shouldn't put yourself down like that....you really are a good person and should have higher self esteem than that!
  #103
Old 09-08-2009, 12:06 PM
You shouldn't put Land Cruiser Owners down like that....you really are a good person and should have higher self control than that!
Fixed it for ya!
  #104
Old 09-08-2009, 12:12 PM
Fixed it for ya!
Ya can't fix what ain't broke....silly boy! Get that thin Runner Iron replaced with Cruiser quality iron yet?
  #105
Old 09-08-2009, 12:13 PM
Nope. Went stronger than Cruiser Iron. I did do some rough sketching and measuring for my rear tube fenders though. LOTS of rubbing on the trail yesterday.
  #106
Old 09-08-2009, 12:15 PM
Rubbing is not a problem just the tires self clearancing! Carry on....
  #107
Old 09-08-2009, 12:22 PM
Lol!!!!
  #108
Old 09-08-2009, 04:17 PM
ElliottB's Avatar
ElliottB ElliottB is offline
New irritating issue
My new interior is great and all, and I love the carpet, gives everything a finished look.
However, the smell is starting to really bug me. It STILL smells like carpet glue/new carpet after like 2 months. I've been letting it sit with the windows open as much as possible, and usually drive with the windows down.
Any suggestions on a deoderizor?
Mine does too. I think it is coupled with the neoprene seat covers. Either way, it gives it that new car smell.
Carl T. Rumplestiltz
2004 Audi A4: 4 RINGS
1981 FJ60: 6 LEAKY RINGS
--KG4JJW--
  #109
Old 12-12-2009, 09:58 PM
Started working on clearing the new tires today...WOW. They hit a lot of stuff.
The most obvious was the fenders themselves, at the back.
So, I got to trimming:
I started with a sawzall to make a clean cut without messing up the paint too much:
Then I got out the plasma and took off the pinch weld only, and then pounded the two halves of the inner fender together. I pounded the inner most part of the fender back first, and then pounded the outter part over that, which makes about a 3/4" overlap. Also took out the lower part of the rocker weld there, and pounded the lower section of the fender back in a bit too:
I then cleaned everything reall well, etch-primered everything, and when that was dry I put in a bunch of 3M Autobody seam sealant. This stuff worked really well on my tranny tunnel, and I like it a lot.
I did the same on the passenger side, but only took a shot of the finished product because I was pushing to get it done so the sealant could set up over night so that I can put the undercoating on it tommorow.
Tomorrow I'm going to work on the upper A-arms, which rub at full droop only.
And, to boot, my idler, which I put brand new bushings into just a few weeks ago, and haven't wheeled on at all, is now REALLY shot again. My new steering set up is going to be my very next project.
  #110
Old 12-12-2009, 10:14 PM
Can remember, was your pinch seam already clearanced for the 33" tires? Mine looks a lot like yours minus the primo 3M filler and a little less hammer work. I trimmed the seam with an angle grinder a little IIRC before going to the ball peen.
