Old 06-25-2009, 12:00 PM
After a brief delay with welder issues (Miller ROCKS, took REALLY good care of me), I Got back to work.
Frame side brackets and Axle side panhard mount all burned in:
Old 06-25-2009, 12:01 PM
I drilled out the holes at work on a drill press.
This was slow. A lot of stacking/creative leaning, to get things to line up properly, and actually sit without falling:
Even still, I'm going to have to pound this bracket a little once its welded to the frame. Both tabs are leaning about 1/32 or so inboard. Not good. But, easy to fix. However, it means that gussets will have to be done on the truck.
Imagine that the firebrick is actually the frame rail, and that you are looking down on the set up from above (ie through the truck, xray vision style). You can see how the bracket mounts, and how the arm comes off of it.
A good weekend.
I realized I hadn't exactly explained my suspension before, so here goes:
This is a total experiment. I'm going to see how it works. It may work well, and be really cool, or it may suck huge, and have to get changed next winter.
The good part is, if it does need to be changed, I can convert to either a true 3 link, and jeep 3 link, or a different radius arm set up. I'll be out about 65 bucks if that happens.
The idea came from staring at an 80 series land cruiser and listening to the owner complain about his front radius arms being rock magnets.
After staring for a few minutes, I thought to my self, "wow, those do hang down far. But, if you flipped them on top of the axle, they'd have a TON of clearance." And, so, I kept turning it over in my head, and finally picked up a set of used arms from Slee Offroad for 50 bucks.
I stuck them up under my truck, and was happy to see that not only did they give me virtually nothing hanging below the axle (the rear mount hangs down 1/2", and is smooth), but, when tucked above the bottom of the frame, they were higher up than my leaf spring. Much better clearance all around.
Anyway, obviously I see the issues with this, and there are a few, as well as the fact that it would be much easier to link it, and call it good. However, I like different. I figure I'll see where this goes, and go back to the norm if it doesn't work out.
Back to the pictures
On Saturday, with the help of a buddy, I got things measured, and remeasured, and remeasured, ad nauseam. However, things turned out straight, so thats good.
Setting the pinion angle
Axle strapped down so it wouldn't move.
Tacked in the radius arms. Looking good so far.
That's as far as we got. Troy came over today, and helped me get the rest going.
Panhard in:
Spring buckets in:
Small snag, due to a dumb mistake. I calculated a loaded truck rear axle weight to be 1200 lbs. I wasn't far off. However, I miscalculated. If the truck has a 1200 lb weight on the axle, then each spring has 600 lbs. Bummer. So, I got 18" 300lb/inch springs, thinking they'd compress around 4". Wrong. Loaded, they'll get about 2. So, sending these back, and getting a set of 16". That should be about perfect.
Before Troy left, we hauled out his spare, which is the tire and rim set up I hope to run. I like it!
I booger welded in the frame brackets tonight. I don't know what it is, but I can't for the life of me make pretty welds upside down. Practice makes perfect I'm sure, and I've gotten all the tips and tricks. I just suck at it. Oh well.
Old 06-25-2009, 12:02 PM
Slow progress. Lots of grinding, welding, etc...
Axle is done, and ready to go back under the truck.
Here is a shot of one of the radius arm brackets gusseted in:
And my favorite part, a little bling:
More progress. Got a lot done:
First off, here is a shot of the truck with no weight in it, besides the transmission. It'll have about 300 more lbs in the back, which, when added, makes the rear sit at a perfect height. Which is stellar!
Here is the flat Belly:
And, a shot of the motor mount, so you can see why I didn't feel that lifting the motor was needed:
And a quick interior shot showing how it fits inside. The Pass seat fits! It will be close but, I can make it work...
Old 06-25-2009, 12:03 PM
Got more work done.
Truck now moves under its own power.
Got the old crossmember torched out, and the new one put in:
Hole cut for the tank:
Tank in:
This was cool. Lots of clearance under the tank. I didn't think it would sit up that high. Very cool
Lastly, got the horseshoe crossmember dealt with.
Started on the tranny tunnel. One cross piece is all, as it took a little adjustment to change from welding 1/4" to sheet metal. Burned a few holes before I got it dialed in. I will likely go to oxy/acetylene for the rest. Its much easier to keep from burning through with that.
Old 06-25-2009, 12:04 PM
This weekend I got my ARB reinstalled, plumbed, and working. Put in new diff studs, new seals, and got my breather nozzle put back in.
Also got the passenger side of the tranny tunnel done. I gave up on adjusting wire speed and found a setting that worked, and then ran a million tack welds. Doesn't look great, but its strong. Dr Frankenstein anyone?
I was very happy with it. Even with just one side done, the floor has stiffened up almost to the point where it doesn't move. I can BARELY flex the driver side. Once I'm done with this, I will be covering everything with body/seam sealer so it looks a little better.
Got the tunnel done save the screws to hold the top plate on. Have to buy those and the weather strip first.
Seats fit in the factory locations, but raised 1" in the rear via 4crawler spacers and a support I welded in.
Also, the shift boots were just set on there for the pics. They too need to be bolted down.
Old 06-25-2009, 12:05 PM
A somewhat big update:
After the last update, I was somewhat burned out, so I didn't do too much for about 2 weeks. I did get everything Seam Sealed, primed, and undercoated.
From there I did the interior. I will get some pictures of that just as soon as I get the radio back in. I put down window flashing, which I found that 1 18 dollar roll covered my passenger area with two layers everywhere except the tranny tunnel. I didn't do two layers on the tranny tunnel because of clearance issues with the seats.
I then redid a TON of wiring, which had been somewhat of a cluster before this. All wires are now soldered, and loomed, and attached to the factory harness.
After that, I cleaned about 100 lbs of dust out of my heat/cooling tubing, and reassembled my dash completely with the exception of the radio (a bit more wiring to do for the CB and Sirius).
The other major thing that has changed is the rear suspension. I flex tested the truck with the 300 lb/inch springs, and the radius arms. I had all of 4" of travel, which wasn't going to work. The radius arms just bound up too much. Not to worry though.
This weekend, I redid the rear suspension and painted the rear axle. It is now a 3 link. I simply cut the back mount off of the radius arms, and added a 3rd, upper link. This corrected my pinion angle, and allowed the truck to flex MUCH better. It now flexes several inches more than the leaf springs. Its not a bunch of flex, but that's okay, because, as I'm still IFS, the rear does not need to flex a ridiculous amount.
I also built my front bumper, minus my tow hooks, and my buddy Troy built the main beam for my sliders. Bumper is 1/4" thick tube, with 1/4" mount to the frame, and 3/16" bracing. Its a beast, but it should hold up.
I now only have some tube work to finish, and they can go on the truck!!! Then, a belly skid and this sucker is ready to wheel.
On to the pictures.
What the new link started as:
Flexing out, with the new bumper:
Droop:
Stuff (actually can stuff a little farther, but the tire was really hitting the back outter corner of the fender, and the hill was just starting to tip the truck. In other situations, it still has another inch to 2 inches of compression):
Suspension:
Here you can see the cut off radius arm:
Upper link:
All in all, this gives me the flex I wanted with a TON of clearance. Those radius arms REALLY give nice ground clearance. I'm happy with it.
