Old 03-28-2006, 03:56 PM
Drew Eckhardt
Guest
Posts: n/a
Default FOR SALE: 1970 Chevota FJ40 - best offer
I haven't had time for this for years, and just accepted an out-of-state
position which they'd like me to start arround May 1, 2006. I'd like this
out of my garage soon so that I can stash things there to make room for
contractors inside.
Interested parties can send e-mail to drew@poohsticks.org
1970 FJ40
Hard top
Baby blue
350 Chevy 4-bolt (cast crank)
Felpro gasket set
World S/R torquer heads with CNC bowl blend
Manley stainless steel valves
ARP head bolts
ARP rocker arm studs
ARP small head header-bolts
Crane Kool nuts
1.6:1 roller-tip rockers
Comp Cams XE262 cam
Edelbrock performer intake
Quadrajet carb
Stewart high-flow water pump
Robert Shaw high-flow thermostat
HEI distributor
Block hugger headers
New fuel pump
Saginaw power steering conversion
Howe aluminum radiator
Stant racing cap
Red top Optima
Cast iron bellhousing
Includes sheet-metal covers
Advance clutch slave mount
14" flywheel (resurfaced)
New 11" clutch
SM465
Advance Adapter
3-speed transfer case
Rebuilt parking brake
New parking brake cable
Pro-mac twin-stick shifter
Front disk brakes
Knuckles out grafted on from a 1979 FJ40
Warn freewheel hubs
Rear disk brakes
TSM GM kit (Monte Carlo calipers)
Wilwood proportioning valve
1975 1" brake master cylinder
1978 FJ40 booster + proportioning valve
Danny Warden adapter
Autometer mechanical temperature and oil pressure gauges
Problems:
It seems to have developed an electrical short when I last tried to start
it a few weeks ago : the ammeter pegs out as soon as the key is switched
to the on position. The same thing happens when all of the fuses are
yanked.
The power steering box needs to be rebuilt.
The carb probably needs to be rebuilt. If nothing else, it's completely
out of adjustment.
I never got arround to having a front drive shaft made after installing
the SM465.
Driver's seat needs to be re-upholstered
I'd want to install a new fuse block.
There is rust in the rear channel, quarter panels where they meet the
channel, and front of the quarter pannels.
There are a few holes in the floor to clear shifter linkages. Some one
should tack sheet metal over these.
The bed inside needs to be painted.
Best offer.
Old 03-28-2006, 05:25 PM
OK....I'll start... $50
KØUBN
Old 03-28-2006, 05:38 PM
$100! going once..
Old 03-28-2006, 07:53 PM
$105!!!
any pics?
Old 03-28-2006, 07:57 PM
timmbuck2's Avatar
Default heh
$150 AMERICAN dollars.
PICSPICSPICS!!
T
* 00 LC
* 99 Saab Convertible
* 76 Piggie
* 1996 T-100 with 396k miles
has a 2008 FJC
KDØTIM
Old 03-28-2006, 08:12 PM
Convert's Avatar
Convert Convert is offline
$200 :yeahdude:
Pics????
Dan Reinmuth
47 Bantam Trailer/RTT
71 FJ40 project
TLCA 13269
KØVRT
Old 03-28-2006, 09:58 PM
Whew....fast bidding.....daughter threw in some cash too...$225
KØUBN
Old 03-28-2006, 11:11 PM
$318.65. I'll prepare a cashier's check...
Originally Posted by nakman
Old 03-29-2006, 09:18 AM
FJBen's Avatar
FJBen FJBen is offline
$341.76 woot woot
TLCA#15530
96 285's OME 's ride
Old 03-29-2006, 10:26 AM
$350 is as high as I go without pics..
HTML code is On
