Old 08-20-2009, 12:09 PM
treerootCO's Avatar
Event Coordinator
Default Snowrun - headgasket report
Purchased at the rally, zero compression on 4 and 5.
Here is what we found.
According to the PO, the engine had a new headgasket installed and it lasted a week. The gasket appeared to be covered in permatex and the head bolts must have been torqued to 200ft pounds. We are going to buy new head bolts, already have a new OEM (new design) headgasket, and will check the head and block for warpage. The third pic is a broken slipper.
www.root45.com
www.risingsun4x4club.org
TLCA #14133
Old 08-20-2009, 12:12 PM
So the gasket has a bit of a weak spot showing but what's wrong with the timing chain guide?
Old 08-20-2009, 12:13 PM
treerootCO's Avatar
Event Coordinator
John broke it The top of the slipper is missing.
www.root45.com
TLCA #14133
Old 08-20-2009, 12:42 PM
Snowrun's Avatar
Snowrun Snowrun is offline
Treeroot should have warned me
Old 08-20-2009, 12:53 PM
So the gasket has a bit of a weak spot showing...
I see more than a bit of a weak spot...Looks like 1/2 of the cross section is missing - of course the cross section above that does appear to have a weak spot
Old 08-20-2009, 01:09 PM
You mean the 80 doesn't have Siamese cylinders?
Old 08-25-2009, 08:34 AM
Snowrun's Avatar
Good news!!! The cylinder head wasn't warped.
Old 08-25-2009, 08:42 AM
Nice! Now get it together and lets abuse it!
KØUBN
Old 08-26-2009, 09:21 AM
Snowrun's Avatar
Hopefully we will have the cylinder head back on tonight. I have no way of checking if the cylinder block is warped or uneven so I am crossing my fingers. Hopefully we will have the rig running by this weekend.
Old 08-26-2009, 09:47 AM
treerootCO's Avatar
Event Coordinator
http://www.toolzone.com/acatalog/Too...ribe_2909.html
Central Tools / Central Lighting CEN6429 Precision Straight Edge - 24" Long
PRICE:
$85.37
Use with your feeler gauges to measure head, block, flywheel straightness (warpage) for every application from small engines up to heavy-duty diesels
• Made from high quality heat treated steel
• 1/4" thick for great stability
• Precision ground to +/- 0.0002" per foot
• Tough epoxy coating
• Convenient hang-up hole
• 24" overall length
K-D Tools KD 2274 Metric Feeler Gauge
PRICE:
$9.76
• 25-blade gauge measures clearances from 0.04 to 1mm
• Blade sizes:0.04, 0.05, 0.06, 0.07, 0.08, 0.09, 0.10, 0.15, 0.20, 0.25, 0.30, 0.35,0.40, 0.45, 0.50, 0.55, 0.60, 0.65, 0.70, 0.75, 0.80, 0.85, 0.90, 0.95 and 1mm
• Blade Lengths: 3" long
www.root45.com
TLCA #14133
