  #31
Old 08-10-2010, 11:25 PM
I might look into some kind of UV protectant - it can't be that expensive and may save the headlights so they don't have to be redone so often?
  #32
Old 08-11-2010, 07:48 AM
Beater's Avatar
Beater Beater is offline
I have been using a product call plast-x polish, that works really well. It's available at autozone. I use it for the motorcycle screens and such, it works.
john (johnny) henley
  #33
Old 12-26-2014, 12:50 AM
Any long-term effects from one of the protectant films? Matt? John?
So I made an attempt to polish the GX headlights a few weeks back, using the Mother's kit, the results were not good. These lenses were really yellow though, just too far gone, fubar'd. The PC plastic feels a little soft even.
For Xmas the got new headlights. Installed those today. But now thinking I should get some kind of protecting film- as these are literally as good as they're going to get right now. Install requires removing the bumper, plus a few other bits.
  #34
Old 12-26-2014, 09:11 AM
LARGEONE's Avatar
LARGEONE LARGEONE is offline
It must have really pained you to put that stock bumper back on
Is that the first time you've ever taken a stock bumper off and didn't put a heavy duty one back in its place?
Paul
KE0OLZ
1967 FJ40 - Nearly Stock
http://www.vrbo.com/322094
  #35
Old 12-26-2014, 01:08 PM
Possibly.. yes the thought definitely crossed my mind, was halfway to an ARB install.
  #36
Old 12-28-2014, 09:10 AM
Squishy!'s Avatar
Squishy! Squishy! is offline
I've always used clear bra over lights. It hold up to the heat just fine and when it yellows just replace it.
-Justin Morgan,
TLCA #23166
"RedChili"-1987 Super Beast
  #37
Old 12-28-2014, 02:28 PM
Jenny Cruiser's Avatar
The only way I have been able to bring back headlights as far gone as yours is to wet sand and polish them. Just for kicks you should spray some bug repellent on a good paper towel or cloth and see what that does. You might be surprised.
http://youtu.be/2iUNiaYrzFQ
"If you compromise the process you're an a$$hole when you start out and you're an a$$hole when you get back."
"If you don't go when you want to go, when you do go, you'll find you've gone."
"We shall meet in a place where there is no darkness."
  #38
Old 01-03-2015, 04:01 PM
I have used 1000, 3000, then Flitz polish on a drill with buffer on it. Tape everything off and go to town for 20-30 minutes. The key is sealing them up with a UV protector, I usually use some high quality wax and forgetaboutit!
  #39
Old 01-03-2015, 05:51 PM
I'm done doin Al's on her Jetta. dropping $$ on new lenses next. There's somebody doing just lens replacements on the later model plastic lens jettas so it makes it easier, $89 rather than hundreds for an OEM light assembly.
The ones on there now yellow in a matter of months and now I can't get them perfect anymore, it's just annoying. I tried several products including ones with UV protectants.
  #40
Old 01-03-2015, 06:25 PM
baja1d's Avatar
baja1d baja1d is offline
Bug spray with 20% Deed works awesome. Add a little toothpaste and they look brand new!
Travis Hurley Owner/ C.E.O.
