  #31
Old 02-22-2010, 01:32 PM
Default Failed emissions!
Failed emissions, and no, it wasn't the gas cap.
CO measured 14.3325, limit 15.0000 (barely passed)
NOx measured 3.5782, limit 3.5000 (failed)
The documentation suggests that high NOx could be a faulty EGR system. I have been running with the EGR disabled since this thread started, and haven't seen the CEL come on since..
My 80 has also been virtually dormant for a month or so- our daughter moved up in car seats, so the Taco has become the kid hauler.. which left only 2 days/week that I could take the 80 to work, which usually turned into one day. Then a little over two weeks ago I got a ticket in the 80 for expired registration, they must have sent the renewal to my old address and I never even thought to check the license plate so rather than risk another ticket, I have been just taking the truck until I had time to mess with the 80.
Yesterday I finally made time to swap small tires onto the 80 so I could go to the emissions place, had been a solid two weeks since the 80 was even started. I drove it around for 10 minutes last night, then to work this morning, then over to the emissions place. I am wondering if I just drove it a little more would that warm things up enough to pass.. or do I need to do something more serious here, like actually fix the system I've attempted to bypass. I need to read up more on the mud thread from home tonight.
Here are the test results: 4mb .pdf file
  #32
Old 02-22-2010, 01:47 PM
Tch2fly's Avatar
Tch2fly Tch2fly is offline
High NOx is the result of high combustion temps, the EGR system inject an inert gas (exhaust) which cools the combustion so a inoperative system could cause the failure (especially since you only missed by a bit).
A cool engine should help not hurt (but could have hurt the CO).
High combustion temps can also be due to a very lean mixture but obviously that is not the case here.
Mike W.
  #33
Old 02-22-2010, 01:54 PM
I also had high CO- measured 14.3325 out of 15.0000. A little more reading suggests a dirty air cleaner, I think I've got a new one in the tool box so I'll change that out just to be on the safe side. I'm half thinking if I just drive off this tank of gas (probably 5 weeks old?) and fill up with a new tank of 91 octane that I can pass next time no problem..
I'm going to post up to that EGR thread in the mean time just for fun.
  #34
Old 02-22-2010, 03:14 PM
Tch2fly's Avatar
I saw that (my disclaimer about a lean mixture NOT being a problem here ). Keep in mind that changing any one of the three, NOx/CO/HC usually has some effect on the others.
Your rich mixture could also mask a higher combustion temp issue (extra fuel cools the burn) so dropping the CO could actually raise the NOx further.
Mine failed because it was super lean due to bad O2 sensors. New O2 sensor and the richer mixture dropped temps and NOx values.
Mike W.
  #35
Old 02-22-2010, 04:03 PM
powderpig's Avatar
I think returning the timing to stock or maybe retarding it a little would help as well. Most of us set the base timing to a bit more than stock and this could create some of this as well. I think you also need to drive it a bit more. The fuel has settled some after 3 weeks. The ethenol settles out in due time, so it will also attract some moisture in the tank if it can.
I need to strap on the emission tires and head to the station as well, I am due to work on the 80 as well.
  #36
Old 02-22-2010, 04:20 PM
Good luck sir! My e-tires are at the house besides the garage if needed...
KØUBN
  #37
Old 02-22-2010, 04:27 PM
Are you saying my timing as been advanced? I mean it's cool with me if so, but there have only been two of us poking around under the hood and I'm pretty sure I don't know how to do that...
That's what I was hoping to hear... I will drive the 80 all week and try to get through most of this old gas, hopefully I don't get pulled over again in the process.
  #38
Old 02-22-2010, 04:35 PM
Kevin what kind of tires are they- are they AT's? could I borrow them? My 255 Maxxis sounded like hell on those rollers, everyone in the place looked over to see what was making all the noise and shaking the earth when the guy had it up to speed... it got squirrely a couple times too I was worried he was going to lose it. Maybe a little less rolling resistance would be a good thing for the numbers too?
  #39
Old 02-22-2010, 05:16 PM
Bikeman Bikeman is offline
I would talk to or PM thefatkid, Brian, for some ideas. He has so much experience with EGR related to 80's and the 3.4 conversions he has done, as well as worked for Slee for a time. He basically took the 3 codes my LX had including the 401 code and the next day it passed with flying colors. Not to discredit Robbie, the one and only Cruiser God!
Mike
2001 Honda XR400 with goodies
  #40
Old 02-22-2010, 05:23 PM
treerootCO's Avatar
I have new plugs, wires, cap, rotor, PCV, and air filter if you want to borrow them. They are all Toyota and sitting in a box. Let me know.
When I go to the emissions place, I over inflate the tires for less rolling resistance, change the oil, install new air filter, time the engine to spec, make sure all electrical devices are off for them to test, open all windows and sunroof(they don't throttle it as much if they can hear the engine/tires), drive a minimum of 50 miles on a new tank of gas, and add two bottles of Heet (Red bottle) to the tank. I also have a new gas cap sitting on the shelf because that really burns me when I pass and they fail me on the cap.
www.root45.com
www.risingsun4x4club.org
TLCA #14133
