Old 10-19-2009, 06:46 PM
Mendocino's Avatar
My junk is getting rewired in Fort Collins and should be done by the end of the week. This will include all the underdash mess. You may want to look at the results before you make. a decision. Our setups are pretty similar.
Jeff
Old 10-19-2009, 08:49 PM
TIMZTOY's Avatar
TIMZTOY TIMZTOY is offline
I personally don't care for the Painless engine conversion harnesses. Either rewire the harness for your app or get a Howell or Turbo City harness. Both H & TC use all circuits and sensors and both are very good at burning chips! If I was to buy one today for myself I would call Turbo City!
Hay thanks ben. I've herd good and bad things about painless. Are you sayig that the painless burns up chips ?
TLCA # 20314
Step by Step Bed Bob
Old 10-19-2009, 09:10 PM
It's Kevin and no, Painless doesn't burn any chips....that would be your burden if the engine is anything different than stock configuration. Rereading your reply...."burning" chips is a generic term for re-flashing a modified map onto a E-Prom to suit the modified application that the engine is being transfered into.
KěUBN
  #24
Old 10-19-2009, 11:42 PM
TIMZTOY's Avatar
That's how I always understood "burning chips as" that's why I was confused. I just read it out of context. So what is it about painless that you don't like ? Or is it just that turbo city has a more complete set up? I'm going to check out TC tonight. What's the story behind "uncle ben" if your name is Kevin? Just sounds like there might be a interesting story there
TLCA # 20314
  #25
Old 10-20-2009, 06:31 AM
Mendocino's Avatar
... What's the story behind "uncle ben" if your name is Kevin? Just sounds like there might be a interesting story there
Tim, check out this thread, it explains most folks screen names.
Jeff
  #26
Old 10-20-2009, 10:50 AM
timmbuck2's Avatar
Tim please take some pictures of the pretty stickers that are on your truck.
* 00 LC
* 99 Saab Convertible
* 76 Piggie
* 1996 T-100 with 396k miles
has a 2008 FJC
KDěTIM
  #27
Old 10-23-2009, 11:07 AM
jettaglxdriver's Avatar
jettaglxdriver jettaglxdriver is offline
Some pics of the 40.
Where his leak was.
The Intake manifold removed.
Thank you for calling. Press1" for English, press "2" to disconnect until you have learned to speak English
TLCA# 19853
1982 FJ60
1991 Toyota Paseo 38MPG baby
1995 JettaGLX VR6turbo project car
  #28
Old 10-23-2009, 11:13 AM
timmbuck2's Avatar
yes those ARE zipties holding the fan shroud on.
the shop looks awesome!!!
* 00 LC
* 76 Piggie
has a 2008 FJC
KDěTIM
  #29
Old 10-23-2009, 11:21 AM
The shop just needs powa and a huge air compressor.
TLCA# 19853
1982 FJ60
  #30
Old 10-23-2009, 01:46 PM
TIMZTOY's Avatar
Hahaha there not that bad ! The wife might like them. And there all skulls anyways.
what zip ties ? You can't even see them In Those pics. And the fan is bolted to the radiator and the radior is bolted to the support. The whole assembly is zip tied to the front grill
oo yea you can sorry. I'm on my little iPhone screen
TLCA # 20314
