Old 11-02-2009, 02:32 PM
Make the tubing a little more robust and you have a roll cage too. For those times when you just slip off a mountain shelf road.
KDěRCH
Old 11-02-2009, 02:44 PM
Tch2fly's Avatar
Tch2fly Tch2fly is offline
My other thought is just scrap that idea, and instead do an internal support cage of some type-so you've got a couple bars below the rack rails, and some legs that run down to the wheel wells/truck bed? In that situation your topper isn't really doing anything other than acting like a fiberglass washer for your RTT support system, and keeping the load from swaying side to side.... but all the load is transferred down to the truck bed. I kind of like this idea better.
I swear an internal support system was available from some manufacturer. I thought it was Rhino-Rack but can't find it in their on-line catalog. I have a hard copy catalog at home and will check it tonight.
Mike W.
Old 11-02-2009, 02:47 PM
I poked around Expedition Portal last night and found one guy who say his fiberglass cracking, another who said just a topper was causing the bed to spread.
Were those ARE toppers? I found a lot of happy ARE/RTT users on there and none had issues. Plus I'm thinking that the metal 5 foot beds on our rigs would be more rigid than longer beds or composite beds on later model Tacos. so maybe the spreading is a non-issue.
At any rate, I'm going to try it and I'll let you know how it holds up. I was hoping to get the ARE and tent mounted up before our Arizona/Utah trip later this month, but I will have to special order the topper with all the features I want and they said 3 weeks.
  #24
Old 11-02-2009, 03:11 PM
Bikeman Bikeman is offline
How about Yakima cross bars/towers on the DC roof and leave the topper alone? The no-drill Q-Towers have proven themselves on gutterless roofs for years.
Mike
2001 Honda XR400 with goodies
  #25
Old 11-02-2009, 03:59 PM
Might be worth a try. Do you have 3 pair with clips I can borrow??
  #26
Old 11-02-2009, 04:10 PM
You know, the internal skeleton idea, that is exactly how a WilderNest is built... There is a molded in steel frame that is pretty strong and does not flex much normally. In fact it only deflects about two inches when it must hold up the weight of a truck, so a few hundred lbs is no prob.
  #27
Old 11-02-2009, 05:26 PM
Tch2fly's Avatar
Here is what I had seen, the Rhino-Rack Ute & Canopy Rack System
Link to brouchure
When I was looking I came across this from ARB.
I am sure you can come up with something more cost effective but at least it shows proof of concept
Mike W.
  #28
Old 11-02-2009, 09:38 PM
Yes! that Rhino design, or the ARB one, that's what I'm talking about. Looks like the ARB one mounts to the side of the bed while the Rhino one goes all the way down? but the Rhino one just pokes through the topper with a big hole.. I think we can do better, but I like the approach..
edit: here's the thread where the guy mentions cracking, not sure if it's ARE though http://www.expeditionportal.com/foru...ad.php?t=28567
  #29
Old 11-02-2009, 09:59 PM
Seems like all you need is a rib that follows the contour of the inside of the shell that runs from bed rail to bed rail under each rack cross member. I'm seeing 3/4" tubing, a bender and welded plates on each end. Very much like a internal roll cage that fits snug under the shell. Tie the internal ribs to the topper ceiling and to the Yakima or Thule feet on the roof, with, I dunno, u-bolts or maybe tabs on the ribs. The fiberglass in a topper is pretty strong and the goal is just to minimize flex to keep it from cracking.
If it was me I would just mold in metal or wood reinforcement into the inside and ceiling of the fiberglass, but I could care less about appearance. You can see part of the 'Nest frame in this photo. There are 4 rectangular tubes, one at each corner, connected along the side with horizontal members over the windows. The whole thing is then covered in structural fiberglass.
  #30
Old 11-02-2009, 10:11 PM
Yeah now you're talking Dave, bent 3/4" tubing with some feet would be sweet, heck I'd even settle for miter cut 1" square... the front legs would just rest on the wheel wells, the ones in back would tuck nicely between the windows on the way down.
