Old 04-09-2006, 01:37 PM
Default cruiser axle parts
three 4.11 diffs $60 ea
rear axle housing for a 40
course spline birfs
ft 40 inner axle shafts
course selectro hubs
drum brake parts
more...
Old 04-09-2006, 08:29 PM
Kipper's Avatar
Kipper Kipper is offline
Administrator
course pinion or fine on the 4.11's?
Old 04-09-2006, 08:34 PM
Silly question but what could you possibly need 4:11's for?
Colorado Trail Patrol
Stay on the Trail!
Old 04-09-2006, 09:06 PM
course.
Old 04-09-2006, 09:35 PM
tcarlson78 tcarlson78 is offline
three 4.11 diffs $60 ea....
Will the diffs fit the front and rear? I can't remember and I don't have time to look it up. If they do I am interested in one of them.
Cheers.
Troy Carlson
78 FJ40, Dark Green (when clean), TBI350, th350, 33 BFG/AT, Lockers F/R, SR, SUA, Power Stearing, RDB, 9/12K winch, and an anoying TC that likes to mark its territory now and then.
Old 04-09-2006, 10:05 PM
Cheers.
They are the same f&R but if you need them for your '78 you need fine spline pinion and these are not.
Stay on the Trail!
Old 04-11-2006, 06:42 PM
Kipper's Avatar
Administrator
Friend of mine with FJ60 wants to run 33's.
Old 04-11-2006, 09:39 PM
for a bit more, i might be able to scrounge up the proper slip shafts from 40 driveshafts to match the pinion. then just swap onto the 60 driveshaft. that's how i'm running 4.11s on my 60
Old 04-11-2006, 10:31 PM
bigbluefj's Avatar
Honorary Canuck Member
Default cone washer and stud's
i need a couple of cone washer's and some stud's for some reason the two parts place's here in town can't find either..
snaped off a stud sometime back awhile so it's for the forty 1974 going to try to find before i go butt if i don't and you can help please bring to moab with you..
kevin
Old 04-11-2006, 10:35 PM
kevin
Toyota stocks them.
Stay on the Trail!
HTML code is On
