Old 12-10-2009, 11:38 AM
CardinalFJ60's Avatar
Default my 60 has Alt on top
Bruce, what you describe sounds like my 60. My Alt. is on the top, middle/PS of motor, AC comp. is down below.
Robbie's got my 2f out doin' some stuff to it, include AC comp - I bet he could chime in with some recent experience.
Old 12-10-2009, 01:44 PM
from IH8MUD...i thought this was from an FJ60, but it doesn't show an AC compressor? Maybe it's just a later 40 2F with no AC?
Old 12-10-2009, 06:31 PM
That is not from an FJ60, it has the slot on the big ole nut for the hand crank. On the FJ60, this is a nut with no slot. All the FJ60 2Fs that I have seen also have a three row crank pulley. The thermostat housing and water pump are also missing the connections for the oil cooling line. Presuming these have not been changed on the engine, I would agree with you that it is a 2F from a 40/45/55 of late 70's vintage.
Old 12-10-2009, 07:08 PM
Originally Posted by 60wag View Post
Jeff, is that a 40 or a 60 motor? I thought my 60s had the alternator on top and the AC comp on the bottom. Does that bracket common bracket botl to the block or is it the engine mount bracket?
From an 84 FJ60. Originally from Treeroot, then to Timm, then to me, Now Mike has it. I took a bunch of photos for just such an occasion because it appeared stock, fully smogged and unmolested.
Old 12-10-2009, 07:40 PM
I thought all 60s were the same - both my '82 and '84 had the alternator on top. In Jeff's picture, I can't tell if its a 3 row crank pulley or not.
Old 12-10-2009, 09:26 PM
3 row. For AC.
Old 11-18-2010, 10:48 AM
Let's resurrect this thread.
I found this information on belt routing:
http://forum.ih8mud.com/60-series-wa...t-routing.html
There's a couple diagrams that show what the belt routing is for US and Canadian spec Cruisers.
But what I don't know is what row do each of the belts go on? Can someone take a look at their FJ60 2F engines and help me out? Right now my guess is:
1st row (closest to engine) - Crank-Water Pump-Smog Pump
2nd row - Crank-Alternator-Power Steering Pump
3rd row - Crank-Air Conditioning Compressor
It would be super cool if that was right.
EDIT: Based on some more reading I think it may be like this:
1st row - Crank-Air Conditioning Compressor
2nd row - Crank-Water Pump-Smog Pump
3rd row - Crank-Alternator-Power Steering Pump
In which case I need to do some more thinking...
EDIT AGAIN: Found some pictures, looks like my second guess was right:
