Old 01-08-2010, 12:47 AM
TIMZTOY's Avatar
TIMZTOY TIMZTOY is offline
Tim,
When is your next day off? How does Sunday look for you? If you're open and if Sunday works for Loki you guys can come down to my place and we should be able to knock this out.
Loki you may want to pick up a pak of high quality sawzall blades if we have to do frame cutting. I should have everything else needed including a welder in case we cut too much off.........
i think that im working sunday.. for me to get any particular day off i need at liest 7 days notice.. but we do close at like 6 or 7 or 8
TLCA # 20314
Step by Step Bed Bob
Old 01-08-2010, 12:36 PM
Loki's Avatar
Loki Loki is offline
I'm available tomorrow (Friday) after 2 PM and then any time on Sat/Sun. Let me know what works for you.
If Windsor is a lot closer for you and you want to go to BigJohn's place, no problem either way. Let me know. Randy
I'm thinking Sunday if that works. And Windsor looks to be about the same distance either way but it doesn't matter, whatever is good for everyone.Thanks!
Paul Hoisington
N5HOI
TLCA #19340
1997 FZJ80 Charged, Locked and Loaded
Old 01-08-2010, 01:20 PM
Paul,
Sunday is fine, do you want to shoot for a 9 AM start? Bring your pals and whatever type of beer you like. My cell is 303-319-8976. My address is 1376 Columbine Drive, Franktown, CO. Let me know if you need directions. Once you pull in the paved driveway you will see another drive that heads off to the left. Follow that around behind the house to where the shop is, then just come on in. Randy
Old 01-08-2010, 07:05 PM
Loki's Avatar
Sounds good, I'll be there. Thanks again!
Paul Hoisington
N5HOI
TLCA #19340
