Old 04-12-2015, 07:07 PM
Kipper's Avatar
Kipper Kipper is offline
Administrator
Default Sienna transmission work?
Our AWD 2007 Sienna, 120k miles is having transmission issues. It is throwing a PO793 code and driving really sporadically. I changed the fluid and the two transmission speed sensors related to the code no luck. Anyway, at this point it's beyond what I have time to deal with. Any advise on independent shops around Arvada to take it? Anyone in the club know this stuff looking for some side work? Let me know!
2005 UZJ100 - 1966 FJ40 - KD0TQS
Old 04-12-2015, 07:24 PM
simps80's Avatar
simps80 simps80 is offline
Atlr didn't mind working on my sienna
Mike | KØSMP |
Old 04-12-2015, 07:34 PM
Kipper's Avatar
Administrator
thanks Mike, never heard of them, but a quick search shows they are rising sun supporters, I'll give them a call in the morning.
http://www.risingsun4x4club.org/foru...ead.php?t=8747
Last edited by Kipper; 04-12-2015 at 07:37 PM. Reason: added link to another thread
Old 04-12-2015, 10:24 PM
Cleaver Cleaver is offline
Daughters Rav4 was having tranny problems. Dealer wanted to replace ECU and then tranny if ECU didn't correct to problem, $6000. It shifted very poorly, high rpm to next gear, low rpm, really rough, 119kmiles. Turns out the ECU, made by Fujitsu, burns out a couple diodes and tells tranny to run in multiple gears at same time destroying the tranny. Found Magnum Performance in Mo, sent the ECU, sent it back the next day. Runs perfectly $89for diode replacement. Spoke with Mike.
If it has an engine, I really think I need one.
'88 560 SL
'98 100 (0 recalls)
'13 ZL1 (1 recall)
'14 Grand Cherokee (wifes!) (6,7,8 recalls and counting)
Old 04-13-2015, 01:36 AM
simps80's Avatar
Jesse is really easy to do business with
Mike | KØSMP |
Old 04-13-2015, 09:52 AM
Kipper's Avatar
Administrator
Oh man Cleaver, that's tempting to try, I may do that. That's a 15 minute fix. What you describe sounds really similar to how the van is driving. I may see if someone has the same ECU around that I could swap to test that theory. Although, in all my research so far I haven't heard of that happening with my year model, but then again most Sienna owners aren't googling ETC codes.
