Old 04-14-2006, 07:41 PM
Default brake question
Hey all you 40 guys...'77 FJ40 - when I press the brake pedal I get a whooshing sound like air being pressed out of a diaphram. After the pedal goes down a little ways then the brakes engage and the old girl stops. If I repeatedly press the brakes then there is less whooshing and more brake engagement. Is this a sign of master cylinder blowby? After the brakes engage, the pedal elevation holds steady, it doesn't drop to the floor.
Old 04-14-2006, 07:51 PM
Good and bad news.....
Good news...it's not your master cyl!
Bad news....your brake vacuum booster is toast
KØUBN
Old 04-14-2006, 08:43 PM
upgrade to an fj60 booster. max is parting one out...see howmuch he wants. it's bolt up, albeit upside down, but that doesn't affect performance and you've a much better chance of finding a good fj60 booster than a good 40 booster
Old 04-14-2006, 09:27 PM
treerootCO's Avatar
Event Coordinator
Don't run too long that way. Even though you may have brakes, the leaking booster makes the #6 run really really lean. Worst case...you will burn a hole through the piston
www.root45.com
www.risingsun4x4club.org
TLCA #14133
Old 04-15-2006, 10:01 PM
Okay, thanks for the quick responses ever'body. So will a minitruck booster work okay as well? I have a BUNCH of credit at the Yota Yard from my stupid minitruck MAF/ECU screwup last year and have nothing to spend it on.
Hijack: Maybe somebody who needs minitruck parts could hook up with me this summer and help me use that credit...
Old 04-15-2006, 11:58 PM
treerootCO's Avatar
Event Coordinator
pick up all the parts needed for a disc brake swap and sell it as a package deal on the eBay....
www.root45.com
TLCA #14133
