Notices
Old 01-15-2010, 02:16 PM
ttubb's Avatar
ttubb ttubb is offline
Default Its Out!
Finally got around to pulling the donor engine (3.4 V6) from the 96 4Runner. Next a mad dash to pull the 3.0 and complete the swap by CM10. T
KA7TLT - TLCA 13015
Old 01-15-2010, 02:37 PM
Congrats! How do you plan on handling the exhaust RH-to-LH change?
KDěRCH
Old 01-15-2010, 03:19 PM
ttubb's Avatar
Since ORS is gone, I guess I will use the flanges and fab a new crossover. Got any thoughts?
KA7TLT - TLCA 13015
Old 01-15-2010, 03:45 PM
Yeah, I am about to do the same thing... to REPLACE the ORS crossover! I plan to follow the process broadly outlined on Yotatech. Not a lot to it technically. More like, a lot to it grinderly and die cutterly. Then, MAYbe, get it ceramic coated for heat management and erosion control.
If you want to go ahead and put your motor in rather than use it for a jig, I have a motor on a stand I intend to use for the same purpose. If you want to tack it together using my motor.
KDěRCH
Old 01-15-2010, 04:02 PM
TIMZTOY's Avatar
TIMZTOY TIMZTOY is offline
ditch the crossover all togther.. and run tru duels.. if ya really need to run one cat back.. have them join togther after the drivetrain
TLCA # 20314
Step by Step Bed Bob
Old 01-15-2010, 05:10 PM
Gmann's Avatar
Gmann Gmann is offline
Uh, Don't think I agree with that. I would run single exhaust, opposite side from fuel line. It just makes sense. There is really no need for dual setup with a 3.4L. If you were running a 350 or other V8 then I could see the point, maybe.
Brent Gehrmann KD0GWN
2012 4runner SR5
2003 Taco trd (turd) SOLD
2007 Audi A3 S-line, track prepped SOLD
Old 01-15-2010, 06:01 PM
ttubb's Avatar
Thanks for the offer, Bill, but I am in Tucson right now. I am leaning toward the same thing you are, cut, grind, tack and weld. I saw the info on the ceramic coating vs heat wrap. Glad I saw it before I did it.
Are you going to use stainless or mild steel? Terry
KA7TLT - TLCA 13015
