Old 02-01-2010, 10:53 AM
LXBRADY's Avatar
LXBRADY LXBRADY is offline
Never mind the pop up........who went all Shaq daddy on the hoop?
Steve Brady
TLCA # 19524
KD0JVZ
97 LX450
Old 02-01-2010, 11:10 AM
Originally Posted by timmbuck2 View Post
Isn't the reason for a p-trap to keep sewer gasses out? If you are just dumping to a hose out side is there a need for a p-trap?
Yes, exactly. And precisely why I was thinking of just getting rid of it- it would be pretty odd for us to actually "plumb in" at a campground, where you'd use that benefit. And substantially less likely it ever happens again depending on how successful BFE is at CM. btw, your camper doesn't have one..
Steve, it was the wind that knocked it down, Gavin can't dunk yet-
Old 02-01-2010, 01:17 PM
If this had the shower it wouldn't be where the sink is, would have been where I'm about to put the fridge most likely, but a separate drain. You dump your sink into a bucket? Not that you needed another project, but adding a drain would be a pretty simple mod... on ours I just reduce it down to a garden hose then run a 20' hose away from the camper. Then again it's just water & tooth paste, so maybe the bucket ain't so bad..
Ya got me there
As for the sink drain...I probably didn't describe it very well but I imagine it is similar/identical to yours where the water from the sink goes into the drain, down a tube to a connection on the floor leading to an outlet outside, underneath. On that I could attach a length of hose to route it away from the trailer or into a drain but we just use a bucket to catch the water at the outlet underneath
  #24
Old 02-03-2010, 02:55 PM
link for weight distribution.http://www.trailercanada.com/axle_position.htm
I'm trying to figure out if can cut the front of my trailer frame and extend it to fit 2 motorcycles on the deck. Issues currently are: current deck is 24" and rated to carry 200 lbs. I want to carry my motos 260lbs each. There are 2 propane tanks in front of the deck and a big battery. My thought is to take measurements. Measure actual tonge weight. Work the math with estimated weights and location of bikes, firewood, battery, lp tank. To see if this is even possible. Getting rid of 1 propane tank. saves 25 lbs. I've thought about upgrading to an E2, but that's a bunch more money and I don't want the bigger camper just bigger deck. I *think* I'm trying to add 24-30" of deck and 350? Lbs additional weight over the current max of 200 lbs. My camper is currently in storage, so at this point I'm looking for feedback? I've searched mud and some other pop-up sites. Also I'm planning on replacing the 2" ball to something more "off-road" thoughts or suggestions? pintle is off-road (I think?)
  #25
Old 02-03-2010, 03:17 PM
I have the smaller one. grey. I'd like to make it more like the yellow, but not yellow.
  #26
Old 02-03-2010, 03:26 PM
end up with something like this
  #27
Old 02-03-2010, 04:09 PM
Me thinks your biggest issue will be tongue weight...520lbs of bikes plus propane tanks, battery, etc. that far out on the "arm" will drastically change things.
  #28
Old 02-03-2010, 04:33 PM
I modded this from a pile of steel
  #29
Old 02-03-2010, 05:10 PM
  #30
Old 02-03-2010, 05:33 PM
Farnham, what about putting the bikes or one bike on the back to balance out the weight? Does it have a receiver hitch on the rear? Add one and get one of that moto racks for a receiver then beef up the front for a single moto there.
Because I also think putting them both up front will screw up your tongue weight unless you add more behind the trailers axle, a lot more.
