Old 01-16-2010, 11:01 AM
coax's Avatar
coax coax is offline
Default 285/75/16 Sport King AT's (4) - $250
Finally came to a decision to go the dual tire set up with snows in the winter which means the AT's need to go. They are Sport King AT's and came on my 80 when I bought it 7 months ago. I'd say about 1/2 to 2/3 tread remaining. All tires held air when they were taken off about a month ago.
The slight catch is when I bought the cruiser these tires were aired up to ~85PSI and two of the tires had a very slight bulge on the outer sidewall. After airing down to a more reason able 35psi, they pretty much disappeared. I'm definitely not a tire expert but figured this wasn't good and as such am selling the tires pretty cheap with the caveat that they should either be inspected by someone knowledgeable or run on a lighter vehicle than the 80 or at low speeds. That being said, I drove them for about a 1000 miles on the 80 before buying the winter tires and had no problems. Maybe I'm just paranoid.
Tires are located in Estes Park but I work down in Broomfield so could potentially meet up with folks. Asking $250 for the set. I also have a 5th tire same brand/same size/new that's currently my spare that I would potentially sell also.
I also have a patched Durango A/T in the same size. Free to anyone that wants it. May hold air, may not. Tread is worn pretty unevenly so definitely only for use as a spare.
I can take more pics if anyone would like.
Corey
-Corey
'74 project pig (sold)
Old 01-20-2010, 08:52 PM
coax's Avatar
Sale Pending...
-Corey
HTML code is On
