Old 01-20-2010, 08:03 PM
ttubb's Avatar
ttubb ttubb is offline
Default New Crossover Pipe - 5VZE swap
Attached are pics of the old (original) crossover and the new one I had made today. I am going to have it ceramic coated prior to installation. This is for the 4Runner 3.0 to 3.4 swap. T
KA7TLT - TLCA 13015
Old 01-20-2010, 08:07 PM
Nice!
Colorado Trail Patrol
Stay on the Trail!
Old 01-20-2010, 09:14 PM
RockRunner's Avatar
Very nice, can't wait to see the finished product.
Thanks T aka Tom KR0MPS
TLCA #6136
Old 01-21-2010, 12:49 AM
TIMZTOY's Avatar
TIMZTOY TIMZTOY is offline
looks great.. im not a fan of the cross over tubes.. ive always opted to run tru duels.. much better HP and throttle responce.. and a hell of a lot easer to run the exhaust. expectually on custome setups..
TLCA # 20314
Step by Step Bed Bob
Old 01-21-2010, 06:27 AM
On the original, is the fat section just a heat shield or a cat? Are you going to have a heat shield on the new one?
Old 01-21-2010, 07:35 AM
ttubb's Avatar
It is a heat sheild. The point of ceramic coating is to insulate the pipe. They coat the inside as well as outside. The actual pipe temp is sustantially lower as the ceramic prevents heat absorbtion and transfer. T
KA7TLT - TLCA 13015
Old 01-21-2010, 08:19 AM
The "fat" section is actually a flex joint isn't it? Stops cracking of the manifolds due to bind after heat expansion.
Stay on the Trail!
Old 01-21-2010, 08:33 AM
ttubb's Avatar
It appears to be very solid. I think it is just a heat shield but I guess there could be a slip joint inside.
KA7TLT - TLCA 13015
Old 01-21-2010, 09:40 AM
STOP!
Cut the middle out of the crossover and weld in the flex coupler from the original.
DAMHIK.
KDRCH
Old 01-21-2010, 09:52 AM
Ok so I'll admit to being a 3.4 swap luddite... but why do you need to run the exhaust down the other side, anyway?
