Old 01-22-2010, 07:40 PM
rover67 rover67 is online now
Default FJ40 Spring under lift options
yes yes, I know... do your research.
BUT, I was wondering what folks in the club are running on their 40's that are still spring under.
Hell for stout? OME?
Should I stop trying to wonder and just get OME? Thats what I'm leaning towards since the OME springs and shocks have done OK on the 60.
tell me to buzz off if it's a topic you guys don't feel like discussing.
FWIW, I am going to stay spring under and am just looking to run 33's at this point. I'm also sticking with the stock steering setup even though it has it's drawbacks.
Old 01-23-2010, 01:31 AM
Marco,
My 40 has what many consider to be a POS Rancho suspension on it with the adjustable Rancho shocks (RS9000s I think)...I think it actually rides pretty good, but that might be because it is old and maybe worn out - IIRC folks consider the Rancho suspension to really stiff
On my '76 40 it had an SOR suspension (whatever that was they sold back then) and it rode like crap compared to the '74. It was "new" so maybe it just never got broken in...
That's all I have experience with...
Old 01-23-2010, 09:08 AM
I think the HFS suspension can give you 4" of lift while the OME is less, but should be fine for 33's.
I'm running the Downey 4 Inch lift. It was stiff as heck when I put it on, but much softer now. Ride is nice when the rig is loaded up with gear. My only complaint is that the springs are narrower than stock, so the shackles are a bit bit wonky. Downey is out of business now, so not sure you can get them anymore.
Old 01-23-2010, 09:09 AM
I'm interested in this as well. I could probably list off the lift systems that are on the 40s of most of our club members; base kit, shackle type length, u-bolt orientation, shocks and who's done a shackle reversal. Ok, maybe I can't list it off, but I know I've had conversations with each 40 owner on these details. I've even ridden and drove a few.
Perhaps, we should gather a bunch of 40's some morning and swap out drivers in rotation so that everyone could get first hand experience with all the variations.
Old 01-23-2010, 09:24 AM
Should have done that on the 40s Only run!
Old 01-23-2010, 09:47 AM
Jacket Jacket is online now
You know where to find me if you want to try out the OME setup.
Old 01-23-2010, 11:03 AM
I had the OME on mine with a SR when she was my driver. No complaints with ride quality as it was very good. But in the end I wish I would have just done the SOA and been done with it. roughly the same money and room for bigger tires.
Old 01-23-2010, 11:47 AM
If your only doing 2.5+ OME is hands down the best quality and ride. If I was to buy a 4"+ today I would go for BDS or Alcan. But that's just me.... Spring overs can be done cheaply but you will do it again as you wont be happy in the long run. If you do a SO do it right the first time! That is not a cheap option but will save you money in the long run!
Old 01-23-2010, 12:26 PM
Kevin, I guess I don't understand where the increase in cost is with the SOA.
Granted much more labor, but if you do your own cut and turn then it seems to be a wash in my mind. Assuming your existing springs are usable. The money you save on springs should cover a high steer and traction bar if you choose. Spring perches are cheap. Otherwise new shocks, brake lines, etc.. are required for both.
Now if you have to pay someone for all the extra labor then I understand more cost to SOA. Am I missing something?
Old 01-23-2010, 01:08 PM
Your right Corbet! I always assume most folks do not have the tools or knowledge to do their own cut and turn. The high majority of spring-overs out there are hacked. It is labor intensive to do it correctly. A track bar for the rear is also required whether it is fabbed or purchased. The springs on a 40 are designed to be SU so if your going through the efforts to do it right, longer springs will also benefit both the longevity of the springs and the available wheel travel at each wheel. Another factor that has to be considered in a SO is how much lift you will need in the long run. Even at 5" over stock the CG/track width becomes an issue so will you be happy with just wheel spacers or off-set wheels? In my opinion if 36" and larger tires will be the ultimate goal then wider axles might as well be planned in to the build early! If you going with FJ-60 axles you need to either outboard the front springs of come up with another plan on how the chunk will fit the springs.
