Old 01-28-2010, 10:01 PM
Default 3rd gen 4Runner OBDII port?
I cannot find the OBDII port on my '98 4Runner. Any ideas? There's the diagnostic port under the hood, but no OBD connector by the fusebox or anywhere in the footwell that I can find.
TIA - Steve
Old 01-28-2010, 11:33 PM
TIMZTOY's Avatar
TIMZTOY TIMZTOY is offline
it's located on the driver side. under the dash.. then its to the right side near the center councle up in the corner. (which when siting in the seat its by your right knee) odds are it has a cap on it also to protect the pins from dirt..
TLCA # 20314
Step by Step Bed Bob
Old 01-29-2010, 12:01 AM
JadeRunner's Avatar
Cruise Moab Co-Chairman
Yep, but there's no cap.
Scott Yoder KD0DHP
Old 01-29-2010, 07:15 AM
I will look at liltte harder - thanks! - Steve
