  #81
Old 02-15-2010, 02:40 PM
Ok your engine mounts are too old. You need to go find some cast steel ones out of the newer 90-95 vintage 3.0l.
That does look like the correct oil dipstick tube boss.
  #82
Old 02-15-2010, 02:59 PM
Squishy!'s Avatar
Squishy! Squishy! is offline
I think I'll just need the passenger side. The driver's mounts up just fine, unless the positioning is just wrong.
-Justin Morgan,
TLCA #23166
"RedChili"-1987 Super Beast
  #83
Old 02-15-2010, 03:07 PM
Originally Posted by Squishy! View Post
Ran into issue #1. this is the passenger side 3.0 motor mount bolted to the 3.4 block. Solutions?
For some reason my reply didn't post earlier...
Make your own mounts! Will end up a lot cleaner, cannot fail and take up less room. Easy fab!
this the cast piece behind the driver's side motor mount I drill into for the 3.0 dipstick?
Looks like it. Find someone who has one of Mikes drill guide or use the new dipstick tube and insert to determine position and angle.
KØUBN
  #84
Old 02-15-2010, 03:15 PM
Squishy!'s Avatar
Don't have the welding resources at my shop. Aaaaand it'll probably cost about the same since you can just get 3.0 motor mounts
Yea mrdoug on CoTTORA is letting me borrow his. Unless someone closer than Loveland has one...
-Justin Morgan,
TLCA #23166
  #85
Old 02-16-2010, 08:38 AM
You could verify against your old man's motorvator.
KDØRCH
  #86
Old 02-20-2010, 09:00 PM
ttubb's Avatar
ttubb ttubb is offline
Default Wiring Review
Hey guys, take a look at this matrix I made for wiring my 4Runner.
I am attaching a spreadsheet I made to match up the wiring from the 91 4Runner (5 speed M/T 3VZE) with the 96 4Runner (5 speed 5VZ-FE). Guys take a look and flag anything you see that does not look right. I think it is self-explanitory but question anything you see.
Thanks, Terry
KA7TLT - TLCA 13015
  #87
Old 02-25-2010, 06:07 PM
Edit: to ttubb
Looks like your missing the reverse switch. Looks ok without getting a EWD and tracing everything out.
  #88
Old 02-26-2010, 06:48 AM
ttubb's Avatar
Originally Posted by thefatkid View Post
Edit: to ttubb
Thanks, I will attempt to find that wiring. Terry
KA7TLT - TLCA 13015
  #89
Old 03-23-2010, 05:42 PM
Squishy!'s Avatar
New question. I just drilled the hole for my new dipstick and the 3/8" is too small for the ones I have(3.0 truck and 3.4 Runner) The ORS instructions don't say anything about drilling any bigger after using the guide. Which one am I supposed to use?
-Justin Morgan,
TLCA #23166
  #90
Old 03-23-2010, 05:50 PM
Cutting your flywheel now.
I don't know about drilling the guide, I never did that one.
