Old 04-17-2006, 05:17 PM
FJBen's Avatar
FJBen FJBen is offline
Default The Soy Latte Build...vintage '93 (i'm boring...just a warning)
Yes, I'm a little odd today, not that that is anything out of the norm, but spending 4+ hours today in a Prius when you are 6'4" can do strange things to you. Good thing a stop by Slee Offroad along the way helped.
Anyways, I digress...here is the psuedo buildup thread for no reason. Started out 5 years ago with a 93 Land Cruiser, 1 owner Female Dr. owner, purchased and every service a Peterson Toyota in Ft. Collins. I've been dying to build this 80 series up...been through many vehicle..hell the last one I had to anyways...the wife has her newer one so I get old faithful.
1993 bone stock with lockers, 194K and the only problem we have had so far is the power steering pump went last year and the rear E-locker that decided to not engage. It's working now, here's a writeup I did..
E-locker replace/fix
The first mod was to remove the running boards, my wife is 5'11" i'm 6'4" so we don't use them, and just hit our shins on them. This was the only mod for 4.5 LOOOONG years. Next was the ARB front winch bumper which paid for itself two weeks after install when we hit a deer at 70 MPH in Kansas....NO DAMAGE thats bueno! So again for 5 months it sit like this...getting better...
so after my the wife got a new ride(s) and I finally got my 80. I put the 285 a/t's on it temporarily.
Then came the roof rack removal so I could "hopefully" fit her in the garage after the lift.
The next just fell in my lap, Actionjackson (the guy who's 80 is on 40's) had me first in line for his used rear TJM bumper tire carrier which needed some TLC(pun intended) for a very nice price, to cheap to pass. The slee was my first choice but would have to wait a year(s) It was missing the mount for the tire carrier and the bearings were TOAST...The guys in my fab shop built a tire mount 3" higher to accomodate a 315 and not hang so low. I got new bearings at a parts place in town and fixed that. everything is getting better!
My initial lift was to be the Old Man Emu "J" lift with 1.25" alum. spacers. After checking a lot on mud people said it worked well with "light" 80's but could get squishy...I decided to stepup to Christo's 4" springs up front and run the J's in the rears for a "level" look. If it sags in the rear, I'll sell those and get his 4" springs.
As for caster, the plan is to use some of Slee's arms when they come in, in a few weeks. These arms alleve the need for a DC driveshaft and are beefy!!! I'll make all the spacers/bumpstops and extend the lines. I'll get the DIY panhard those later as well.
The tires are on order and should be in, in about 2 weeks...they better BE!!! i'm going with the Toyo Open Country M/T, 315 75 R16. Hopefully they'll treat me well.
The lift is "scheduled" to go on this weekend...stay tuned for more
and now some poser pics...
how she sits today:
The used TJM setup:
The part we built, 1/4" steel
TLCA#15530
96 285's OME 's ride
Old 04-23-2006, 04:30 PM
FJBen's Avatar
4" Lift done...mostly..except for caster correction...
TLCA#15530
Old 04-23-2006, 06:05 PM
Sweet! When is the real test drive? Count me in for support crew!
Old 04-23-2006, 10:25 PM
Nay's Avatar
Nay Nay is offline
Looks ready for those 35's
What did you use for panhard correction?
Old 04-24-2006, 09:34 AM
FJBen's Avatar
LOL...if only i could find 35's maybe tuesday...
No panhard correction at them moment...plans are Slee or I know there was another post about someone finding another places (summit or some shop) that had a different version...
TLCA#15530
Old 04-24-2006, 09:39 AM
Looks good Ben
Old 04-26-2006, 07:29 PM
Nay's Avatar
Nay Nay is offline
Here's your very near future on 35" trxus
OME medium is fairly well overwhelmed by these tires...not enough spring rate or shock compression valving...need that new 3" suspension and Bilsteins!!!
Old 04-26-2006, 07:45 PM
Need a little more space between the wells and tires doood! Like this perhaps.....
Old 04-26-2006, 09:12 PM
Nay's Avatar
Nay Nay is offline
Looks good!!! What do you think of the trxus on first impression?
I am sticking with the 3" lift to run 35's...these tires are huge and the wheel wells are starting to swallow 'em up even on 2" of lift...just what I need is more lift and a reason to spend $2K on 37's
Old 04-27-2006, 10:01 AM
FJBen's Avatar
I'll post up pics here shortly...getting ready to drop her off at the tire shop. The 35's should rit nicely with the 4" lift
TLCA#15530
