Old 04-17-2006, 11:55 PM
Default Brake Booster Issues...
Howdy Everyone-
Well, drove around 150 miles in the cruiser today, with a short run up into the mountains, coming down I had to hit my brakes a bit to allow a faster vehicle by, when I did my truck darted side to side... this was new, but I am not sure if it is related.
After driving to the airport and back about an hour and half, my brake pedal was getting a bit stiff but still slowing the 40 down.
By the time I got home today, I was needing to downshift to scrub speed and the pedal was stiff as a board. I was having to stand on it to get it to stop. I also had a bit of fluid coming out of the front cap when I got home... the cap is pretty dry rotted and loose though.
I am thinking it has to be in the booster? Fluid is good, pads are good, these are disks.
What do I start to look for with the booster? How do I check it for proper function?
Thanks-
Drew
Old 04-18-2006, 03:07 AM
Drew,
It sounds more like you have a sticking disc brake caliper. When you stepped on the brake and it "darted" it sounds like one caliper hung for a milisecond then suddenly grabbed the rotor. Your brakes got harder because that same caliper was dragging on the rotor and got really hot, thus heating the fluid (which expanded). I bet tomorrow when you drive it around the peddle will feel more normal again but if you feel the front wheels after you drive it a bit I bet one will be very hot.
