Old 04-18-2006, 03:39 PM
Snorkel 1's Avatar
Snorkel 1 Snorkel 1 is offline
Question Using Toyota switches to control ARB compressor and lockers
I know there is a write up on this somewhere, I just can't find it. I am trying to use a Toyota switch to power my ARB compressor and the factory rotary diff lock switch to control the lockers. I ran the ARB wire harness into the cab now I just need to know which wires to connect to the switches. Any suggestions?
Seth Sauvageau
Rochester, MN
'97 40th Anniversary, OME 2.5" with 35's, ARB bumper & lockers, Warn M12, ICOM radio, CB, dual batteries, auxillary gas tank, etc and now a snorkel
Old 04-18-2006, 04:33 PM
I know nothing, but that's never stopped me from posting before so why start now?
But I do know that Bruce (60wag) has done this in his 60, and he'll be in Moab. and I've seen him trade tech advice for before..
Old 04-18-2006, 08:18 PM
Ahem, Toyota makes a lot of switches; which are you contemplating using? One that's already there, and if so, which one? Be advised that compressors use a LOT of juice and most dash mounted switches won't be up to the task and would be best controlling a relay.
Old 04-18-2006, 11:44 PM
i think he's talking stock 80 switches.
Old 04-19-2006, 02:04 AM
Snorkel 1's Avatar
Thank you for the input . I finally figured it all out. I was making it way to complicated at first.
The toyota switch I used was for fog lights fro an earlier model I think. I ran it through the relay included with the ARB wire harness. Seems to work great and the system is holding air. I connected the solenoids to the rotary switch and hooked a couple relays up to the diff lock ECU plug so the diff lock dash lights work also. Now I just need to wrap and route the wires to finish it off.
Seth Sauvageau
Rochester, MN
