Old 02-24-2010, 07:18 PM
Romer Romer is offline
Seems like it went from 'interesting battery drain problem' to 'pain in the rear battery drain problem'.
Yup, based on what I see it seems to be the battery. Swapping in the old lifeline will tell for sure.
I went down there to buy two for the trailer, glad I bought a third to put in the truck.
Of course, if the Lifeline battery, which is suppose to be the similar technology does the same thing, there could be something else I am missing
Old 02-24-2010, 07:21 PM
So is this a blem 31 from the group buy we did a few months back?
Old 02-24-2010, 08:09 PM
I went down there a few weeks ago and they had 4 left. I bought 3. Not sure if they are from the same pallet or not.
Like I said, I still need to put a different battery in there to make sure I am not missing anything before I take them back
  #24
Old 02-24-2010, 08:41 PM
Does the battery lose charge if its not in the truck?
  #25
Old 02-24-2010, 09:03 PM
I don't believe so. At least when I put it in the truck it was charged after sitting on the pallet and then it slowly died. I doubt they would have charged it before giving it to me.
I will check that when I swap batteris after I take it out
  #26
Old 02-25-2010, 12:56 AM
TIMZTOY's Avatar
TIMZTOY TIMZTOY is offline
have you ohm'd out the wires ? and does the parasidic draw go away when you pull the radio fuse ? if so, ohm out the gound and power wires for the radio.. and ohm the ground wire for the second battery. although im sure you've problly already done most of this. sorry just throwing out ideas.. why not run a marine battery if your just running acccessories off the second battery ? and not starting the truck ?
TLCA # 20314
Step by Step Bed Bob
  #27
Old 02-26-2010, 06:09 PM
I have an Optima yellow top blem that did the same thing as your dekas. It has an inverted cell. I still keep it around because the other cells are OK and it will run an inverter for a while, but I no longer trust it in a critical application in a vehicle.
  #28
Old 03-02-2010, 07:02 PM
Update: The problem is the BLEM battery
with the BLEM, the battery voltage would drop almost 2 volts in 48 hours w/o being able to start
With another battery, after 48 hours of sitting, no perceptible voltage drop at the battery. Rock hard at 12.8V
  #29
Old 03-02-2010, 07:53 PM
Tuckytres's Avatar
Tuckytres Tuckytres is offline
Event Coordinator
Default Just my experience
I also had to return a group 31 (2nd Blem) to Hensley Battery today. The problem I was having was the battery would hold 12.6 volts but once you would put a load on it it would drop to 8.7 volts. If I drove the truck every day it was fine but when it sat for a two or more days the reserve capacity/ CCA was gone.
I hope I don't experience the same problem with the replacement I was given.
  #30
Old 03-02-2010, 07:57 PM
jacdaw's Avatar
jacdaw jacdaw is offline
Good news! So did they give you a new battery to replace the defective blem?
Jon Newquist
TLCA 19964
