  #31
Old 05-01-2010, 05:52 PM
Dr. Schlegs's Avatar
Something does not look right here. I might need new bearings?
TLCA#5366
  #32
Old 05-02-2010, 11:08 PM
TIMZTOY's Avatar
TIMZTOY TIMZTOY is offline
Ouch
TLCA # 20314
Step by Step Bed Bob
  #33
Old 05-03-2010, 10:16 AM
Not to worry, Gunn will machine your crank shaft and check your connecting rods to be bored if needed. They'll then tell you what size of over size bearing to get.
I always use the assembly lube that comes in a tube available at any auto parts store. Then fill it with 15w-40 diesel oil, that has all of the zinc and other additives you need for high friction engines. I would recommend running it all of the time except in winter if you need to run a lighter weight.
