Old 11-14-2010, 08:13 AM
Thread revival......
I've got a gauge/sender issue that pops up occassionally on a SAAB and a scan tool should help isolate the problem. I've read about Scanguage and Ultragauge but do either of them offer a datalogging feature? I don't really need the log but it'd be another cool feature.
Here is a logger that I like but there is no built in display so the PC needs to be active to get any real time info.
http://www.obdcom.com/
It's the last two graphs on this page that have me interested:
http://www.obdcom.com/software-obd.htm
Ideally, I'd like a blend of the two devices: display and logging - anything available that does that?
My SAAB issue is a fuel gauge that sometimes reads low. It could be the sender in the tank, or a problem in the dash gauge according to the forums. Both are expensive to fix but if I can rule out the sender, it'd save some $. I also have a misbehaving temp indicator - again, could be the sender or the gauge. An alternate gauge should either confirm or dispute what the dash reads.
How do the fuel consumption displays work on the Scangauge and Ultragauge? They use a full tank value and a fuel use rate rather than reading the fuel level sender, right? The coolant temp value is read from the temp sender though - right?
Old 12-02-2013, 12:04 PM
I am having trouble getting my Scangauge II to connect.. have tried it on 2 different vehicles with the same results. Just gets hung up "Connecting..." I think I've tried to force every mode at least once.
Can anyone tell me what "mode" they're using? UZJ preferably, but I'll take whatever.
edit: I can do a pic
Old 12-02-2013, 10:19 PM
Well I ended up answering my own question. I called them, they say the correct mode is ISO for Toyotas.. for some reason though, my SG doesn't pick anything up, in any of our cars.
So they're sending me a replacement circuit board, they assure me it's easy to swap out..
  #24
Old 12-05-2013, 08:48 PM
Well to wrap this up, I got the new board installed and all seems well. The detail can be found here: http://forum.ih8mud.com/100-series-c...ml#post8952346
here's the "after" pic:
  #25
Old 12-06-2013, 11:40 PM
No doubt, when I first read your post I was thinking "faulty scan tool".
  #26
Old 12-08-2013, 08:08 AM
ttubb's Avatar
ttubb ttubb is offline
I had the exact same experience with one of mine (I have three). SG was great to repair/replace. Turns out it was a faulty harness.
Great product, particularly the coolant temp for the 80 and the trans temp for towing with my Taco. T
KA7TLT - TLCA 13015
