Old 03-05-2010, 07:19 PM
BobinDenver's Avatar
BobinDenver BobinDenver is offline
Default WTBorrow 80 Castor bushing press tool, jig?
The new 2.5" heavy lift is installed! (Resulting in about 4" of body lift...) Many thanks to Stephen Rudy for his time, tools and techniques.
...except for the small part about the caster bushings. So...
I'm looking to borrow a bushing press tool to push out the old caster bushings. A jig to align the new bushings would be icing.
(Plan B is a hacksaw - your sympathy will be rewarded with your choice of drink and many accolades.)
Thank you,
Bob(inDenver)
-Bob Potter
1995 FZJ80
1987 Jeep Cherokee
Old 03-05-2010, 10:01 PM
Sorry Bob...No tool here...Slee did mine
Old 03-05-2010, 10:10 PM
depending on how rusty, it may take a large press. as schegel, we used a 10 ton press on his and it made some nasty shotgun sounds when they finally broke loose
Old 03-06-2010, 09:14 PM
Default We got it with what I had.
I think it is a subaru SVX transfercase rear output shaft bearing. It even had the step machined into it to keep it centered in the stock bushing.
I ran around it once with the flap wheel for clearance. fit perfectly, except it is too short. I think the inner bearing race was from a 8" carrier bearing.
12 ton press worked pretty doggone well.
The included paper template worked just fine to make sure the offset bushings were in the right places.
KD0FDS
Stephen
Old 03-06-2010, 10:58 PM
Thank you Jeff and Ige for the interest and advice.
And again to Mr. Rudy and his random shop parts for the win! The new caster busings are doing their job.
I'm looking forward to the next project!
-Bob Potter
1995 FZJ80
1987 Jeep Cherokee
Tags
caster, fj80, fzj80, lift, tools
