Old 03-09-2010, 12:40 PM
dirtyXplorer dirtyXplorer is offline
Unhappy New toy (need some help)
Hi, I am new here. Through a career change, my dad ended up giving me his 1978 FJ40. 2F engine with the 4 speed.
It has a few issues that I think might be carb related but I have never delt with a carb before. I did some searching on here and Ih8mud but I didn't come up with much on how to tune these carbs. I am looking for someone local(ish) who could come over and give me a hand getting this thing running better.
The symptoms:
-I have to mess with the choke to get it to idle, it always has to be out a bit
-It runs pretty rough and the idle seems high
-It wont start sometimes after driving it for a bit, I have to let it sit for like 20 mins then try for a while for it to start.
-I pulled the plugs and they were real messy with some white stuff caked on them (running rich/hot???). I am hoping to get some new plugs/cap/rotor in the next few weeks.
-It has also been SUCKING gas down. I know these are bad but it seems to go through half a tank in a weekend of light driving.
It also has some rust through the floor pan but I plan on working on that after I get it running.
Edit: located in Denver.
Old 03-09-2010, 01:15 PM
Welcome.
Wow, that's a beauty. I dig the old school decals.
Sounds like you need a tune-up to try and baseline things. Probably a mixture of things causing your issues. Timing, maybe vacuum and it wouldn't hurt to give the carb a once over either.
Is everything under the hood stock?
Old 03-09-2010, 01:20 PM
Cool truck! Be patient - you're picking up the slack on some 30 years of deferred maintenence.
- Replace intake/exhaust manifold gasket, check intake for cracks under carb
- Rebuild carb with kit from CarQuest (replace secondary diaphram while you're in there)
- Clean ash/deposits from plugs, or replace them.
- Install electric fuel pump to prevent vapor locking/hard starts when hot
- Try to fix the electric carb fan - it should run for up to 30 minutes after you shut the truck off on a hot day.
- Check for other vacuum leaks, proper base timing, a functioning vacuum advance (not rusted shut or hole in diaphram).
- Expect 12+ MPG in all around driving.
Steve
(20 year owner of a stock '78 FJ40)
Old 03-09-2010, 01:28 PM
treerootCO's Avatar
Event Coordinator
Vacuum leak is #1 thing to check. Check or block of your PCV and see if the symptoms are reduced. I use a piece of cardboard to completely block of the carb. If the idle raises just before it dies, you have a vacuum leak.
The fuel thing is either running rich all the time to keep her running or the float and or needle is stuck.
www.root45.com
www.risingsun4x4club.org
TLCA #14133
Old 03-09-2010, 01:36 PM
Originally Posted by MDH33 View Post
Welcome.
Thanks! Everything is stock (I think). It looks like the PO before my dad bought it messed with some of the stuff. It looks like there is an AC compressor and another little thing below it that are missing a belt. I will try to take some pictures.
Steve
Wow, thanks for all the tips! I am on a college students budget so it might be slow going getting through the list. It looks like I should start at the top of the list?
As for rebuilding/adjusting the carb, I have never worked on one before. is it something you can do in an afternoon? Is there some good resources on this?
1978 FJ40 project
1993 4runner
Old 03-09-2010, 01:39 PM
Thanks, Ill have to try the vacuum leak check. A lot of the rubber (tubes, wires) under the hood look pretty old
1978 FJ40 project
1993 4runner
Old 03-09-2010, 01:40 PM
I'm not an expert, but I've rebuilt a bunch of Aisin carbs. If you're not in a hurry, I can go through your carb for the cost of a rebuild kit and a case of good
Where is your rig located?
Old 03-09-2010, 01:42 PM
All of the advice you got above is good. I recently rebuilt my first carb and it went really well. Yours is a bit more complex, but the same principles would apply.
Old 03-09-2010, 01:45 PM
I'm not an expert, but I've rebuilt a bunch of Aisin carbs. If you're not in a hurry, I can go through your carb for the cost of a rebuild kit and case of good
That would be awesome. I am in Denver in the west Colfax/Perry area. I would be happy to get ,food, cash etc. if you could give me a hand.
Is CarQuest a good source for parts like gaskets and the carb rebuild kits?
Thanks, that is a great writeup. Ill have to take a better look when I get home tonight.
1978 FJ40 project
1993 4runner
Old 03-09-2010, 01:50 PM
I would call Kurt at Cruiser Outfitters for parts. He will hook you up with what you need:
http://www.cruiseroutfitters.com/index.html
Tags
carb, fj40, running rough
