Old 03-13-2010, 11:00 PM
Inukshuk's Avatar
Inukshuk Inukshuk is offline
Originally Posted by CBone View Post
Also, if you live at Colfax and Perry, you are smack dab in the middle of the Central Breakfast Club part of town.
x2 and I'm at 21st & Newton.
Old 03-14-2010, 12:41 PM
Since it's been de-smogged you don't need the air pump. They are notorious for freezing up as your's has.
The old AC compressor could have been installed to be used as an on board air pump system.
The ticking noise could be that your valves are out of adjustment, do that first. If it's still there afterwards then you may have a leaking exhaust manifold gasket. If you pull the manifold off to replace the gasket, check the manifold over carefully as the are known to crack and leak.
Old 03-14-2010, 03:07 PM
dirtyXplorer dirtyXplorer is offline
How difficult is adjusting the valves? I know that adjusting valves on my 4runner's 3.0 is a pretty involved process with shims, etc. I have the Haynes but it doesn't look like it says much about adjusting clearances.
Is there any special tools needed?
thanks!!
EDIT: Just found this:
http://forum.ih8mud.com/40-55-series...y-78-fj40.html
Do I just need a feeler gauge?
1978 FJ40 project
1993 4runner
  #24
Old 03-16-2010, 01:03 PM
I am looking at service manuals. I have the haynes but its not very in depth with its procedures.
Is this the one that most of you have?
Here
1978 FJ40 project
1993 4runner
  #25
Old 03-16-2010, 01:26 PM
Get the Toyota Factory Service manual for the 2F. In addition, you're going to need to get the correct year 2F emissions manual, which will help you figure out all the vacuum connections.
Looking at your pics, it looks like the engine has been partially desmogged, which will certainly cause all sorts of running issues. You're going to need to get it set up properly if you hope to get it to pass emissions. Does that smog pump still spin freely?
  #26
Old 03-16-2010, 01:33 PM
No, the pump (the one missing the belt) doesn't turn by hand. As far as I know everything else is there...lol
1978 FJ40 project
1993 4runner
  #27
Old 03-20-2010, 02:35 PM
Ill be tinkering with it for a few hours on this Monday 3/22 if anybody in the neighborhood is free (I can have food/drinks, etc)
Lots to do, thinking of:
Checking/adjusting the valves
finding a possible exhausts leak
Adjusting the carb
Figuring out why it doesn't start sometimes
Does anyone have the 2F engine manual I could borrow while mine gets here?
1978 FJ40 project
1993 4runner
  #28
Old 03-20-2010, 10:45 PM
I have a set of factory manuals for 1978 fj40. They are a little dirty. Make me an offer. PM me.
  #29
Old 03-21-2010, 02:26 PM
PMed back!
1978 FJ40 project
1993 4runner
  #30
Old 03-22-2010, 09:48 PM
Got some work on the FJ40 done today. I replaced the exhaust/intake manifold gasket, what a pain in the ass! lol
1978 FJ40 project
1993 4runner
Tags
carb, fj40, running rough
