Old 03-16-2010, 09:09 AM
In any event, it is the rears that are possibly giving me fits.
That was my point, the rears are mounted properly AFAIK.
Old 03-16-2010, 10:18 AM
RockRunner's Avatar
Bill, I have seen some write ups that use a *eep coil spring in the middle to support the extra weight. I had the page bookmarked for possible future use but lost it somewhere. If I run across it I will post it but try a search I will too.
Thanks T aka Tom KR0MPS
TLCA #6136
Old 03-16-2010, 10:27 AM
Yep, ZUK came up with that one. Without some means of stopping body roll, it would make it MUCH worse. The other one he came up with is coils on each leaf spring bump stop. Not adjustable and a bit ghetto, but folks say it works mah-vell-us.
KDRCH
  #24
Old 03-16-2010, 10:42 AM
When I ran Rancho 9000s on my 60, I tried them upside down to preserve the adjuster knobs. They most definitely stopped acting as a shock. When mounted correctly they started working again.
In order to preserve your off highway flex and improve your on highway stability, I think an airbag system is in order.
  #25
Old 03-16-2010, 11:31 AM
Bruce, do you think airbags are up to offroading? I have heard they won't extend enough, and will get torn up as a result. Roger's idea of one mounted over the diff, where it would not need to flex much, might work though - as long as a swaybar was used to limit the increased potential for body roll on the highway.
KDRCH
  #26
Old 03-16-2010, 12:08 PM
Bill,
Google "Firestone air suspension" then go to North America. They have an entire section devoted to how to design an air ride suspension and they have an 8.5 MG/85 page pdf file with all of the design parameter info in it. Should be able to tell you if you can get enough flex with their products for off-road use plus you can actually call and speak to their engineers.
  #27
Old 03-16-2010, 12:26 PM
That's why I was wondering if they can be mounted on only one side of the bag... so they don't have to extend too far.
  #28
Old 03-16-2010, 08:33 PM
Nay's Avatar
Nay Nay is offline
I'd invest my money in a higher end set of shocks and accept that fact that light towing is going to compress my springs a bit.
I know you like the 9000's, but they are so far below a baseline high end shock in performance. Of course, $700 - $800 for a much better set of shocks is not chump change, but you buy once and can both rebuild/re-valve and it's a good investment for a rig that will see hardcore offroad use and a wide variety of road usage.
These 9100 series bumpstops are also interesting:
http://www.bilsteinus.com/offroad_9100bump.php
  #29
Old 03-16-2010, 08:59 PM
Bill,
Also go to theshockshop .com and check their prices for air shocks. They are like $150 per pair for Ranchos or Gabriels. As long as you get the right length/travel for your application I think they would work offroad OK. This is what I recommended you check into, not the Fox offroad racing units that are $400+ each.
  #30
Old 03-16-2010, 10:02 PM
bigbluefj's Avatar
Honorary Canuck Member
The air bags only get ripped if they rub on anything ie: sharp metal parts, one fellow in the RMLCA runs them on his 80 and this is what has happened to him in the past, install mistake on his part..
bigbluefj
