Old 03-16-2010, 11:22 AM
Originally Posted by leiniesred View Post
I suspect I can only get it to work right using the HOME PRI method. I think I have different freqencies set to #1 spot on the various memory banks at this time. That would explain why I see 430.000 flash by on my PRI scan sometimes.
I'm betting that you have 430.000 set as the first memory location. This is not the #1 in a bank or whatever, but the actual #1 (e.g. 001) location. That is the default priority memory location if you have not selected a bank. So in VFO or Memory mode and NOT using a bank the radio's '001' location is the one banged every 5 seconds. The quickest change to just make memory '001' something more meaningful.
Old 03-16-2010, 05:19 PM
jacdaw's Avatar
jacdaw jacdaw is offline
Originally Posted by FJBRADY View Post
Thanks Bro, I will check that out!
Let us know how it goes. Otherwise you bought a really fancy scanner with a useless mic. We'll get you talking on repeaters!
Jon Newquist
TLCA 19964
Old 03-27-2010, 01:38 PM
Hey Bruce, since you have an FT7800 and so do I, care to export your programming, then I can just lift it from you and import it?
KDěRCH
Old 04-02-2010, 10:56 PM
mad chemist's Avatar
mad chemist mad chemist is offline
What a great reference! I just got my ticket a few months back, and will be driving down to Cruise Moab from Seattle. Hope to meet some of you guys there. Now I can add "programming my 8800" to the list of things to do before leaving.
Old 04-03-2010, 05:22 AM
I don't have a cable or software to export the setup. The excel file is the best I have at the moment.
