  #31
Old 04-01-2010, 08:30 PM
powderpig's Avatar
Yes, I would. It has age and would last a while more, but for 18-19 dollars for the seal. It is cheap insurance. Get some 220 to sand the vibration pulley seal area,then finish with some scotch brite pad in either the red or green(green is finer usually).
  #32
Old 04-01-2010, 09:08 PM
TIMZTOY's Avatar
TIMZTOY TIMZTOY is offline
just my .02 from a not so good photo.. sorry if im not correct.. what does the fluid smell like ? thats tipcially the #1 give away to what fluid is leaking.. i would also replace the front main and oil pan also.. it looks rather torn up, and looks to be seaping.
TLCA # 20314
Step by Step Bed Bob
  #33
Old 04-01-2010, 09:21 PM
The higher up leak is the bottom of the oil pump cover, which is what I suspected from the beginning. It is definitely not PS fluid. I have had to add 2 quarts of oil since returning from the CM prerun. PS has held level.
Thanks Robbie for confirming what I suspected. I will order the oil pump cover seal/s and a crank seal for good measure. Calling Cdan in the morning.
  #34
Old 04-01-2010, 09:28 PM
TIMZTOY's Avatar
kewl beens ..
TLCA # 20314
  #35
Old 04-01-2010, 09:43 PM
you have a monster torque wrench for the crank?
