Old 03-22-2010, 02:00 PM
Originally Posted by Romer View Post
Not sure why Matt would need that. It's for testing to see if your coolant is still good and needs changing
I use it for checking what my coolant is "rated for" - i.e. if I am at the proper mix of 50/50 for -32F protection
When I did my flush and fill I ended up more in the 60-70% antifreeze range vs. 50/50 and my temps reflected that. When I attained the proper mix my temps came back down to "normal" for me.
Old 03-22-2010, 02:10 PM
Those hygrometers tell you the ratio of coolant-to-water in your mix. The more coolant you have the higher the specific gravity and the higher the float (or floating balls of varying density).
BTW, Jeff, you realize that the specific gravity of anti-freeze is not linear and actually above 70% concentration with water starts to go down? Yeah, at 70% the specific gravity of propylene glycol + water has the same specific gravity as 35%. You really need to judge the accuracy of your tester with your own brain because if it seems odd it might just be odd.
Old 03-22-2010, 02:19 PM
Cool, thanks for the tip Dave! So, you are saying that at a 70% + concentration of antifreeze things (like the tester) will start behaving as if it were only a 35% concentration? Good to know. I knew I was high on the coolant side but I was more in the 60% range. Now I am (or think I am) at 50/50 - Doesn't sound like you can get to 50/50 with too much coolant but you might wonder why you can't get it to come up by just adding more coolant to the mix
Old 03-22-2010, 02:25 PM
Yes on the behavior. Although, don't use the numbers as exact but just an approximation. It's also only true for propylene glycol (e.g. the so called non-toxic anti-freeze, such as Sierra brand), not ethylene glycol.
Old 03-22-2010, 02:49 PM
Or when to bottle.
Paul McCumber - Longmont, CO
1995 FZJ80 -- 2013 Mini Cooper S Hardtop - 2013 Toyota Prius
"It's a 1970 Firebird, the car I've always wanted and now I have it. I Rule!" Lester Burnham - American Beauty
Old 03-22-2010, 03:59 PM
I added some more 50/50 coolant mix this morning. When I checked the AT fluid, it was still full. I'll check it again tonight after I have driven 10 miles.
Originally Posted by nakman
Old 03-22-2010, 04:54 PM
Originally Posted by pmccumber View Post
Or when to bottle.
I was going through my mind the whole time... Oh yeah.
Old 03-22-2010, 06:21 PM
Romer Romer is offline
Thanks. That's good to know
