Old 03-29-2010, 02:02 PM
Bikeman Bikeman is offline
Default Tow Hook Bolt Torque Spec.
Does anyone with a FSM know what they should be at? Also, what are the winch to winch plate 3/8" bolts supposed to be torqued at? S#$%bilt isn't returning my calls.
Mike
2001 Honda XR400 with goodies
Old 03-29-2010, 04:41 PM
Well I came up empty - I have the electronic copy here at work which leaves a bit to be desired as far as navigation is concerned....
This might help: http://www.sleeoffroad.com/installat...ear_Bumper.pdf
If I'm thinking of the right bolts, Slee suggests 70ft/lbs
If that doesn't help, check out the attached .pdfs and compare your bolts
As for the winch, I just made them as tight as I could get them, which is probably wrong but its what I did
Old 03-29-2010, 04:44 PM
powderpig's Avatar
Not really a tow hook as much as a tie down when they load them on the big boat. But we use them as such. I would not torque much more than 70lbs as well. Use some sort of antisieze as well, life it be nicer when you take them out.
Old 03-29-2010, 04:59 PM
2 or 3 grunts for a skinny guy like you. If you have a beast of a friend helping tell him only one.
Old 03-29-2010, 05:48 PM
I just downloaded some fastener torque charts that should work. I'm reusing the tow hook mounting points for the Metal Tech bumper. Thanks all.
Mike
Old 03-29-2010, 06:15 PM
LXBRADY's Avatar
LXBRADY LXBRADY is offline
Mike glad you got your info before I posted up "How tight? Wicked tight"
Steve Brady
TLCA # 19524
KD0JVZ
97 LX450
Old 03-29-2010, 07:52 PM
Go until the bolt breaks and back off 1/2 turn.
Old 03-29-2010, 07:59 PM
only go 1/4 turn once it starts to get easy again
Old 03-29-2010, 08:08 PM
You guys will be great teachers at the WBPP
Mike
Old 03-29-2010, 08:45 PM
TIMZTOY's Avatar
TIMZTOY TIMZTOY is offline
Just a good 1/2 second zap on the air impact should do. It's not that important anyways. Lol
TLCA # 20314
Step by Step Bed Bob
