Old 04-02-2010, 04:13 PM
Very cool. Looks like it was meant to be there. All hail the 3.4
Old 04-02-2010, 05:33 PM
cool
Old 04-02-2010, 09:33 PM
ttubb's Avatar
ttubb ttubb is offline
Originally Posted by MDH33 View Post
Very nice Terry. Did you have to custom configure the wiring, or was there a kit?
I did the "wiring diagram" splice. I went to the Toyota site and pulled both the 91 and 96 general diagrams, along with specific ECM and system diagrams. I matched functions and power sources to ensure the engine harness would interface with the body harness. I had the complete 96 4Runner to work with so it made it much easier than just getting an engine and ECM. Having both vehicles side by side was a HUGE help and I would advise anyone doing this swap to buy the entire vehicle before starting.
I now have a bunch of 96 4Runner parts (5 speed, wheels from a Tundra, rear axle, new rack and pinion, rear axle and many other parts.
The YotaTech website has a section dedicated to this swap with much good info. Anyone with questions I can answer, let'r rip. I made a spreadsheet of the splices I did with the wiring harnesses, which I will share. It is year specific. Terry
KA7TLT - TLCA 13015
Old 04-02-2010, 10:27 PM
Terry, Yeah, you need to remove the restrictor. Something else: the 5VZ power steering pump is weak for an IFS steering box / crossover steering application. It will die suddenly and without warning (just leaves you with Armstrong steering; its life might be helped with something like Royal Purple PS fluid and a cooler but... I dunno).
PSC sells a power steering pump kit that takes care of that and more (will drive a ram if you decide on that). I had some troubles with mine whining above 3K RPM, but it turns out it was a failing bearing that PSC took care of for $20 (plus shipping which wasn't too bad).
I also don't like K&N, so when I was looking for ways to spend my 4 Wheel Parts Warehouse gift card, I stumbled upon a dry conical filter that does a much better filtering job (AFE). Washable, too. I also run a K&N foam overfilter, to catch all the nasties, and preoil it with No-Toil Oil (learned from the motorcycle world. WONDERFUL stuff, VERY tacky, and VERY easy to clean with water and their cleaning powder and nitrile gloves).
KDěRCH
Old 04-02-2010, 10:47 PM
ttubb's Avatar
Thanks for the info, Bill. If you happen to have the make and P/N of the filter, I would appreciate it. I found the PSC site. The restrictor comes out on Monday. Don't know if I will have time to do the PSC kit prior to Moab. Hope the pump lasts til then. Terry
KA7TLT - TLCA 13015
